  • Replies 72
Hells yeah, that's better than my guy.
I'm in mate.
cool.. even if they ae shit, for $16 who really cares?
i've emailed them my address and will letyou know whenthe soarer set arrives and i'll take some pics
hopefully they will make them and put them for sale on eBay thus saving me the hassle of having to organise distributing them all..
Also remember there are a couple of different colours of buttons across various models.....
Button colour won't matter, as the stickers are text only, everything else is clear see through.
Hmmm, wouldn't you see the Jap writing as well then ???
Check out the ones on ebay above, they are black.
If they do not match the colour of your buttons closely, they may look a bit poxy....
Awesome, thanks mate. Will be waiting!
ok i've uploaded two pictures of how it turned out, but let me first explain..
the soarer buttons arrived via express post and the seller has kindly given me this set to have a look at myself and see the quality
i lined up the buttons and my first impressions were
- the buttons are the set specifically for the soarer so as their buttons are all smaller, there were none that were of a size big enough to cover an entire button so i couldn't really get a full idea of it
- the colour of the sticker was a gloss jet black, but the buttons we have aren't as strong in colour, more of a dark-grey-ish matt black
so i cleaned the buttons and stuck on one of them to see how it looks
note: this requires a set of tweasers to line up peroperly.. i did not line it up properly because i was in a rush. i also did not stick it down fully because i had intended on removing it immediately after and didn't want to it to leave residue
the pictures show how it looks
my impressions:
- you can see the colour is a little darker
- you can also see that its the wrong size. i believe that if it were the correct size it would look much better you wouldn't even see the edges
- you can also see that i haven't stuck it down proerly and that it is on an angle
- i think it looks good if it were able to be made in a matt finish
so what does everyone think for $16 a set?
i have measured out buttons and will give him the correct sizes...
should i tell him:
a) go ahead
b) go ahead, but make the buttons a different colour
c) go ahead but make the stickers a "matt" finish like the stock buttons
d) don't bother we don't like them..
personally i think option "c" but i'll wait for a couple of opinions before i tell him exactly what we want
cheers,
Warren
in case anyone wants to know, i will also give him the following information:
top row sizes:
22mm horizontal
18mm vertical
words: NAV / SPLIT / VIEW / INFO / MAP / MENU
bottom row sizes:
20mm horizontal
11mm vertical
words: IMAGE / TV / ZOOM IN / ZOOM OUT / BACK
top row sizes:
22mm horizontal
18mm vertical
bottom row sizes:
20mm horizontal
11mm vertical
Yeah,
If they could match the colour to the stock buttons it would make it much better.
Could you get him to make them to size?
If not size, i'd be happy to try a set if they were correct colour in matt finish.
Cheers
he will make them to our sizes, its just that the set he sent was a set for the soarer whichhas much smaller buttons
he has yet to make any for us, and was waiting on the outcome of this to determine if we wanted to go ahead, then he would cut them to the correct sizes and put the correct words on for us
as far as the colour goes, i feel that if they were in a matt finish the colour would be right, i think its just the gloss that looks funny
maybe i'll see if he can make a set to the right size and matt as a second test. i'll happily pay for a test set that is V35 specific but i'm not sure if they will make a "one-off" or if they only make in batches
Yeah well i'm in.
Once he has made them. Will he place them on ebay so we can buy them off him direct to save you distributing them?
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
