  • Replies 72
Hells yeah, that's better than my guy.
I'm in mate.
cool.. even if they ae shit, for $16 who really cares?
i've emailed them my address and will letyou know whenthe soarer set arrives and i'll take some pics
hopefully they will make them and put them for sale on eBay thus saving me the hassle of having to organise distributing them all..
Also remember there are a couple of different colours of buttons across various models.....
Button colour won't matter, as the stickers are text only, everything else is clear see through.
Hmmm, wouldn't you see the Jap writing as well then ???
Check out the ones on ebay above, they are black.
If they do not match the colour of your buttons closely, they may look a bit poxy....
Awesome, thanks mate. Will be waiting!
ok i've uploaded two pictures of how it turned out, but let me first explain..
the soarer buttons arrived via express post and the seller has kindly given me this set to have a look at myself and see the quality
i lined up the buttons and my first impressions were
- the buttons are the set specifically for the soarer so as their buttons are all smaller, there were none that were of a size big enough to cover an entire button so i couldn't really get a full idea of it
- the colour of the sticker was a gloss jet black, but the buttons we have aren't as strong in colour, more of a dark-grey-ish matt black
so i cleaned the buttons and stuck on one of them to see how it looks
note: this requires a set of tweasers to line up peroperly.. i did not line it up properly because i was in a rush. i also did not stick it down fully because i had intended on removing it immediately after and didn't want to it to leave residue
the pictures show how it looks
my impressions:
- you can see the colour is a little darker
- you can also see that its the wrong size. i believe that if it were the correct size it would look much better you wouldn't even see the edges
- you can also see that i haven't stuck it down proerly and that it is on an angle
- i think it looks good if it were able to be made in a matt finish
so what does everyone think for $16 a set?
i have measured out buttons and will give him the correct sizes...
should i tell him:
a) go ahead
b) go ahead, but make the buttons a different colour
c) go ahead but make the stickers a "matt" finish like the stock buttons
d) don't bother we don't like them..
personally i think option "c" but i'll wait for a couple of opinions before i tell him exactly what we want
cheers,
Warren
in case anyone wants to know, i will also give him the following information:
top row sizes:
22mm horizontal
18mm vertical
words: NAV / SPLIT / VIEW / INFO / MAP / MENU
bottom row sizes:
20mm horizontal
11mm vertical
words: IMAGE / TV / ZOOM IN / ZOOM OUT / BACK
top row sizes:
22mm horizontal
18mm vertical
bottom row sizes:
20mm horizontal
11mm vertical
Yeah,
If they could match the colour to the stock buttons it would make it much better.
Could you get him to make them to size?
If not size, i'd be happy to try a set if they were correct colour in matt finish.
Cheers
he will make them to our sizes, its just that the set he sent was a set for the soarer whichhas much smaller buttons
he has yet to make any for us, and was waiting on the outcome of this to determine if we wanted to go ahead, then he would cut them to the correct sizes and put the correct words on for us
as far as the colour goes, i feel that if they were in a matt finish the colour would be right, i think its just the gloss that looks funny
maybe i'll see if he can make a set to the right size and matt as a second test. i'll happily pay for a test set that is V35 specific but i'm not sure if they will make a "one-off" or if they only make in batches
Yeah well i'm in.
Once he has made them. Will he place them on ebay so we can buy them off him direct to save you distributing them?
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
