  • Replies 72
Hells yeah, that's better than my guy.
I'm in mate.
cool.. even if they ae shit, for $16 who really cares?
i've emailed them my address and will letyou know whenthe soarer set arrives and i'll take some pics
hopefully they will make them and put them for sale on eBay thus saving me the hassle of having to organise distributing them all..
Also remember there are a couple of different colours of buttons across various models.....
Button colour won't matter, as the stickers are text only, everything else is clear see through.
Hmmm, wouldn't you see the Jap writing as well then ???
Check out the ones on ebay above, they are black.
If they do not match the colour of your buttons closely, they may look a bit poxy....
Awesome, thanks mate. Will be waiting!
ok i've uploaded two pictures of how it turned out, but let me first explain..
the soarer buttons arrived via express post and the seller has kindly given me this set to have a look at myself and see the quality
i lined up the buttons and my first impressions were
- the buttons are the set specifically for the soarer so as their buttons are all smaller, there were none that were of a size big enough to cover an entire button so i couldn't really get a full idea of it
- the colour of the sticker was a gloss jet black, but the buttons we have aren't as strong in colour, more of a dark-grey-ish matt black
so i cleaned the buttons and stuck on one of them to see how it looks
note: this requires a set of tweasers to line up peroperly.. i did not line it up properly because i was in a rush. i also did not stick it down fully because i had intended on removing it immediately after and didn't want to it to leave residue
the pictures show how it looks
my impressions:
- you can see the colour is a little darker
- you can also see that its the wrong size. i believe that if it were the correct size it would look much better you wouldn't even see the edges
- you can also see that i haven't stuck it down proerly and that it is on an angle
- i think it looks good if it were able to be made in a matt finish
so what does everyone think for $16 a set?
i have measured out buttons and will give him the correct sizes...
should i tell him:
a) go ahead
b) go ahead, but make the buttons a different colour
c) go ahead but make the stickers a "matt" finish like the stock buttons
d) don't bother we don't like them..
personally i think option "c" but i'll wait for a couple of opinions before i tell him exactly what we want
cheers,
Warren
in case anyone wants to know, i will also give him the following information:
top row sizes:
22mm horizontal
18mm vertical
words: NAV / SPLIT / VIEW / INFO / MAP / MENU
bottom row sizes:
20mm horizontal
11mm vertical
words: IMAGE / TV / ZOOM IN / ZOOM OUT / BACK
top row sizes:
22mm horizontal
18mm vertical
bottom row sizes:
20mm horizontal
11mm vertical
Yeah,
If they could match the colour to the stock buttons it would make it much better.
Could you get him to make them to size?
If not size, i'd be happy to try a set if they were correct colour in matt finish.
Cheers
he will make them to our sizes, its just that the set he sent was a set for the soarer whichhas much smaller buttons
he has yet to make any for us, and was waiting on the outcome of this to determine if we wanted to go ahead, then he would cut them to the correct sizes and put the correct words on for us
as far as the colour goes, i feel that if they were in a matt finish the colour would be right, i think its just the gloss that looks funny
maybe i'll see if he can make a set to the right size and matt as a second test. i'll happily pay for a test set that is V35 specific but i'm not sure if they will make a "one-off" or if they only make in batches
Yeah well i'm in.
Once he has made them. Will he place them on ebay so we can buy them off him direct to save you distributing them?
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
