hey mate..
Just send a PM on here to a guy on here with the user "the Mafia"
Tell him what you want re: bov and for sound and so forth...
He'll let you know what to do.
LOL.....yes, he will tell you what he thinks of it too. lol
lol
you guys crack me up
Will the fart machine effect my AFM readings?
Do I need to configure the fart machine to vent to atmo or should I plumb back some of it in to the cabin?
does it produce protein fart type smells or is it more like a night on the booze then maccas before sleeping in the gutter for the night..fart smell?
The most important thing is that I want it for the noise and smell is an added bonus.
Will chicks flash there fun bags and penis holders at me or will it make them feel too comfortable and feel that they can fart too?
Lastly, how do I go about using the fart machine to create a dutch oven experience for mah passengers?
sorry for the questions.
I really appreciate your help bro.
i find that with a fart machine configuration, ur always better off with vent to atmo, the is a risk with plumb back of spontaneous combustion (u may blow a valve)
best of luck
Aif
No it shouldn't. The performance gain will be minimal.
Probably 50/50 would be best, so you don't pass out while driving, but still get a whiff of the fart.
Depends what you feed it. If you've been feeding it protein drinks you'll have a protein filled fart.
No not necessarily. The types that do that are generally skanks. Depends who you want to attract. They may feel more relaxed and fart in your presence too.
If you've got power windows, there's usually a lock button to disengage the passenger windows. Simply lock them and have your window wound up, and release the fart. For best results 100% plumback in to the cabin, just be careful you don't passout yourself.
Hope that helps man.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
