I am a bit confused, we have had this at my work (internet cafe) for about 4 weeks now, i played it.... to be honest i did not like it, maybe because i never liked the other CoD games. However my mate sat there for a good full day (seeing as the hours consist of 11am-3am) and towards the night he said... wow i clocked it already. Does this sound possible? If so... i am glad i did not buy it.
  • Replies 131
Easily finishable in one sitting. You buy the game for the online play, not the offline.
theres a cheat where you can just sit in one of those booths and just wait it out, but thats a bit anti-the-point... try and back yourself into a corner so that they can only attack from one or two directions... and bury yourself with claymomres dont worry about spreading them around.
I hired this game a few weeks back.. clocked it in one night :down::)
hired it again and gave online a play.. now went out and bought it and lovin it :D.. lvl 21 now after about 10 hours of online play
did that booth thing but... when the chopper gets their i keep on getting killed picking up the other dude and running back..
but in the end i bought it for pc and am now up to lvl 16 in about 5hrs.... so easy compared to ps3 *to connect to servers n stuff*
top game i bought it last sat and finished it sunday (for pc). multiplayer is great. ive played CS & DOD old and source. have any of u tried the mod called insurgency. thats pretty good for a while.
multiplayer has engulfed me. im on every afternoon and sometimes at night. my player name is killerkutz.
question: do ps3 run separate servers to pc online?
I was trying to creat an SAU clan on 360 but it wont allow it. I think it thinks im swearing. Theres alot of things you cant have as a clan tag which sucks. I wanted simply XXX but its not allowed.
Another reason why Xbox sucks :D I have [sau] as my clan tag on ps3. Anyone that plays it on ps3 should join up! I think I'm the only one...
If you play it on PC come over to Ministry of Gaming server, the server is set to hardcore mode. So no hud and it only takes a few bullets to put someone down.
One bullet unless using juggerstand then it's 3. Hardcore is really the only servers I join now.
If it's H/C and shows up in the list with people on it I join mostly the GSA H/C TDM.
Working on gold AK that I will never use just like my gold mini-uzi and unfortunately the gold sniper rifle is the Dragunov. Very disappointing, I wanted to use a gold mini-uzi as my secondary (Overkill perk) when sniping but it wasn't to be, can't choose a camo pattern for a second primary weapon.
I currently detest the G3, it just does not suit my style at all but I still need those headshots.
Ha, G3 with reddot scope FTW. I run around and pop one, MAYBE 2 shots into people and take them down.
I use the Dragunov aswell quite a bit. Its good for taking quick shots at people. I'm still only on lvl 32, but at the rate i'm going i'll be 55 by the end of the week.
I was lvl 55 in two days of play and really it's doable in one with enough active servers.
The G3 is a single shot kill in H/C but it's extremely unreliable unscoped/unsighted when moving around. It's a camper's best friend but that's not what I do. The M40A3 is definately the best sniper rifle with high damage and accuracy but the semi-autos have the advantage in an 'oh shit' situation where you can just fire off a mag in the general direction and only one has to hit.
The M60 rivals the G3 for single shot accuracy and damage and it has higher penetration.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
