  • Replies 131
I'm not sure if it's the same for the consoles but on PC each weapon set has one that can use a 'gold' as a camo pattern after you have completed all challenges for that weapon type eg after completing all kill and headshot challenges in the SMG class you can choose gold for the mini-uzi. The assault class you can get gold for the AK47.
I assume the gold deagle was added as a seperate weapon because there are no camo patterns for secondary weapons.
Its the same on 360 and im assuming for PS3 too.
been playing this since before christmas and cant get of it. as soon as the missus goes to work im on there. on pc and called bulletholes. i think its a good idea that everyone (if they want to)go clan SAU, otherwise its a bit hard trying to remember peoples nicknames, i can do 3 or 4 different servers in one sitting. mainly do team deathmatch on the lowest pings
yeah team deathmatch is the best. I had to change my name :P punkbuster was kicking me for "player name "1" has been kicked for name to short" so i am now "useless". I'll keep an eye out for ya
Your name can display as 1 or even blank if you just stick enough colour codes in front. (^ and a number)
How much does the MP44 suck? Last assault I need to do for gold AK and I have to use double tap just to make it an average gun. At least in H/C it's a one shot kill.
Don't know if I have mentioned this before but I am Helfarch in game.
Edited by DivHunter
Finally upgrade my com with Q6600 & G92 GTS, now I can finally play this game properly.
Game is awesome, being up to 3 - 4am multiple times to play it on the net.
Man I feel like crap now... :D
Still working on gold weapons, getting there for the gold shotty, about 60 hs to go on the pump and I'm done. Not looking forward to doing the M60. The sniper I only use them on selected maps so that will come in time though I've done the best sniper rifle already, the M40A3.
I have very much enjoyed putting a shotgun to the back of multiple sniper's heads even 3-4 in a row and they don't notice until BOOM. Last Stand is the enemy of all shotguns.
If anyone sees iG-Irada tell him he's a noob, iG are noobs and I will teabag him into submission. kthx.
hahaha,
i've finally found a good combination so i can get more kills than deaths. My split is pretty ordinary in my stats though :no:
had a first the other week 6 more assists than kills first time i have ever had over 20 assists.
Over 20 assists? I'm a little annoyed if I get 5. You poor bugger sounds like you don't even have a 1:1 fragrate, mine is down to about 1.8 which is pretty low after working on gold weapons and still having LMG and Sniper to go. It forces you to use weapons you don't like that are unsuitable for a map. At least you get a good idea of just how each weapon does. I made an effort to screenshot my games last night maybe I'll post them up after work.
awesome game. been playing since xmas.
i have it on ps3
my nickname is AUS A_BFG.
its very addictive when playing online.
and atm i have unlocked the 2nd prestige stage and am working thru it ;)
best guns:50cal sniper
p90 with silencer and uav blocker perk
Edited by r33cruiser
For a 'ninja' kit I prefer the MP5, more accurate than the P90 and quieter. That with Bomb Squad, UAV jammer and Dead Silence and it's good times after breaking enemy lines.
The Barrett is pretty garbage in this game, no where near enough damage to justify it's poor accuracy, M40A3 is the duck's nuts of the sniper rifles.
P90 is definately a good CQB assault weapon, a little short range for some maps.
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
