I've worked in the compliance industry for a number of years and came across a motor which had a very usual marking on the engine block when I was attempting to get the engine number. It was in a 1994 R32 GTR Vspec with the an engine number that was something along the lines of the following
R B 2 6
R
7 * * * * * X
(The R should sit directly above the X marking)
I believe the X denotes that the block was sold seperately from nissan. That when a engine block is bought from nissan it will have this marked on it and the block requires it to be restamped. What I don't get is what the R marking above the X stands for. The stampings all look factory, but I could be mistaken. Does anyone know what this R marking could stand for? Does it mean that it is an N1 motor?
I also pulled the front cam cover off and all the bolts where brand new, as if it had come like that from factory. I'm quite baffled to know what it could be..
Edited by Baz
https://www.sau.com.au/forums/topic/192670-rb26-block-with-r-engine-number/
The number on the block that has .........X and then a R above is definatly a R34 Nur engine, these engine's are build by Nissan Motorsport and have the following specs in stead of the STD Rb26:
- R34 NUR cams little different then STD R34
- N1 block (24U)
- N1 piston rings
- piston + conrods weight balanced
- crankshaft weight balanced
- Nismo F112 bearings main + conrod
- N1 oil pump
- N1 waterpump
As you state all the bolts, nuts, the complete bare engine is new from Nissan Motorsport.
Here are some pics of a few I have/had:
Yup.. the engine number on the side of the block was exactly as the same as the one on the picture as above. The only thing I though is that it did not have variable valve timing such as found in the R34 GTR motors. Does that mean that it is not a R34 NUR motor then?
VCT is what I meant to say. Where exactly would the 24U be stamped on the block? Because I'm pretty sure there was a 05U cast into the underside of the block.
No they don't have VCT either. Where do people hear these crazy things?
On the passengers side in line with the collant outlet , close to number 3 cylinder, not easy to see under the turbos, you have to look up from under the car.
  • 1 year later...
G'day,
Can anyone please send me pics of the RRR block engine stamp. I believe the numbers and letters are actually raised not stamped as such, any help would be appreciated,
Thanks
KG
If you read my post above you will note that the Nismo GT block had RRR in caps ( just like the normal 5uand 24U blocks) on the turbo side close to number 3 cyl inline with the coolant pipe.
The engine number is in the normal place on the inlet side near the dipstick, RRR blocks have RB26 NS Axxx, just a 3 digit number from 001 to 200 , only 200 blocks made.
  • 7 months later...
Wondering if R means refurbished or remanufactured?
yeaqh ive seen this on a few cars that had reco's in japland. I stamp all mine to and engrave certain things on the wings to remind me whats inside :)
  • 3 years later...
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
