I've worked in the compliance industry for a number of years and came across a motor which had a very usual marking on the engine block when I was attempting to get the engine number. It was in a 1994 R32 GTR Vspec with the an engine number that was something along the lines of the following
R B 2 6
R
7 * * * * * X
(The R should sit directly above the X marking)
I believe the X denotes that the block was sold seperately from nissan. That when a engine block is bought from nissan it will have this marked on it and the block requires it to be restamped. What I don't get is what the R marking above the X stands for. The stampings all look factory, but I could be mistaken. Does anyone know what this R marking could stand for? Does it mean that it is an N1 motor?
I also pulled the front cam cover off and all the bolts where brand new, as if it had come like that from factory. I'm quite baffled to know what it could be..
Edited by Baz
https://www.sau.com.au/forums/topic/192670-rb26-block-with-r-engine-number/
The number on the block that has .........X and then a R above is definatly a R34 Nur engine, these engine's are build by Nissan Motorsport and have the following specs in stead of the STD Rb26:
- R34 NUR cams little different then STD R34
- N1 block (24U)
- N1 piston rings
- piston + conrods weight balanced
- crankshaft weight balanced
- Nismo F112 bearings main + conrod
- N1 oil pump
- N1 waterpump
As you state all the bolts, nuts, the complete bare engine is new from Nissan Motorsport.
Here are some pics of a few I have/had:
Yup.. the engine number on the side of the block was exactly as the same as the one on the picture as above. The only thing I though is that it did not have variable valve timing such as found in the R34 GTR motors. Does that mean that it is not a R34 NUR motor then?
VCT is what I meant to say. Where exactly would the 24U be stamped on the block? Because I'm pretty sure there was a 05U cast into the underside of the block.
No they don't have VCT either. Where do people hear these crazy things?
On the passengers side in line with the collant outlet , close to number 3 cylinder, not easy to see under the turbos, you have to look up from under the car.
  • 1 year later...
G'day,
Can anyone please send me pics of the RRR block engine stamp. I believe the numbers and letters are actually raised not stamped as such, any help would be appreciated,
Thanks
KG
If you read my post above you will note that the Nismo GT block had RRR in caps ( just like the normal 5uand 24U blocks) on the turbo side close to number 3 cyl inline with the coolant pipe.
The engine number is in the normal place on the inlet side near the dipstick, RRR blocks have RB26 NS Axxx, just a 3 digit number from 001 to 200 , only 200 blocks made.
  • 7 months later...
Wondering if R means refurbished or remanufactured?
yeaqh ive seen this on a few cars that had reco's in japland. I stamp all mine to and engrave certain things on the wings to remind me whats inside :)
  • 3 years later...
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
