Hey all,
Whats the go in South Australia with high mounting a turbo?
Is it a straight out defect?
If so why????
Or is there any way of getting around it?
Is it a straight out defect changing your standered turbo??
Looking to up grade my turbo and new injectors and like the look of the high mount. BUt if its a defect i wont go to the trouble...
Cheers
https://www.sau.com.au/forums/topic/192737-high-mounting/
Not an expert but I believe any aftermarket turbo is a defect. So hi-mounting itself may not be, but since you'll almost certainly have an aftermarket turbo attached to the hi-mount you'll get a defect regardless.
Yer thats what im wondering... is the defect the aftermarket turbo??? or the high mounting??? or both??
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462339
its likely to be both mate.
Give the mob @ regency a bell. They have to answer any questions of this nature you throw at them.
dont give them any personal info of course! :worship:
Edited by MSPEC33
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462358
Yer mate i think ill end up giving them a call.... but yer my thinking is tho whats not defectable!? everything these days will get you a defect lol
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462374
Pretty much! The advantage of a low mount though is that an aftermarket internally gated turbo still looks stock, especially if you have the original heatshielding over it.
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462433
the original point of high mounting was for turbos that wont fit in the original spot because of being too big.
in this day and age its a looks thing. personally, i think it looks awesome, but with the range of turbos available i dont think its necessary.
as for doing it for looks, ive seen a t28 high mount..
oh, and i didnt answer your question, but i did have a bit of a rant.
Edited by ted180
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462514
I have been recommended two turbos for what i want to achive...
Both can be low mounted and both have been said to be able to push out 280 to 300kws. With supporting mods (which i have)
What do you think oif the two choices?
- Garrett GT30/40r turbo machined into a std rb25 style exhaust $2100
- Garret turbo GT3271 $1212
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462690
High mounting is a definete defect and even a low mount aftermarket turbo is a defect if they can pic it up.
The injectors are also a defect as well, but there are ways around this by matching the colour of the stock injectors and spray painting the new injectors the same colour. To run the injectors you will need and aftermarket computer and that is a defect as well.
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462939
haha yer i hear that... i have a power fc but the hand control can be hidden. i wasnt aware injectors were a defect!!!??? there on order at the mo... why tho? do you kno?
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3462962
i have heard rumors that police can defect on the grounds of "suspicion of modification", so even if you have a stock turbo on a high mount manifold it might get undue attention from the boys in blue. and the car will have to be inspected, and who knows the list of changes they will give you!
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3463131
anything with changing turbos etc is modifying the intake system, so its an emissions breach. as would different injectors, ecu etc. No expert, but this is some things ive heard. they can be engineered i THINK, but its pending emissions testing
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3463672
Yep, pretty much anything that will increase percormance wil alter emissions.
Many things CAN be engineered, but it is a very costly exercise, as the testing cost big bickies each time - pass or fail.
My advice is if you want to own a modified car - keep everything you need to return it to stock if defected, drive it in a way that doesn't attract attention and don't have it as your daily driver.
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3464352
Yer the high mount looks so so sexy but i guess its not worth the hassel... just need to work out what turbo to get now... :(:( sooooooo hard!!! :thumbsup::P:):):rant::rant::rant: especially when you know so little about it lol!
https://www.sau.com.au/forums/topic/192737-high-mounting/#findComment-3464400
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
