heh,
found this hot 34 oohhh droooll with whoring BMT stickers on it heheheh i want some to rice up my 32 with.. can u hook me up dr drift? hehhehe seeing ull be doing all the future work on my 32 hahaha..
out of interest what kidn of figures this beast do?
http://www.fullboost.com.au/racing/dragmee...rivals_017b.jpg
mark
https://www.sau.com.au/forums/topic/19276-34-whoring-bmt-heheh/
qikshift - Can hook ya up bro :)
The 34 belongs to a customer of ours, it is now a beautifull package after a long process of getting the package done right. BMT hasn't done much apart from plaster stickers on it and some tuning.
I have driven the 34 on a few occasions and it ROCKS!!!!
mwahahaha..... so many evil 'lines out there...
Doc.
?? What do you mean about the maroon 33??
It seems to be going well, Jet picked it up this evening and all was good. Couple of minor issues for RWC still to be sorted but overall I think the new owner will be very happy....
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
