Nissan
200 SX Series 2(Australian Delivered)
81,000 original kms
Dark Blue
Melbourne, Springvale
RWC YES
Currently not reg. due to not paying rego in time.
Selling with RWC and with 12 months Rego.
$17,500 neg
Louis : 0404 737 906
[email protected]
Modifications.
CES Dump pipe ceramic coated.
High Flow CAT.
X-Force 3 inch exhaust
Excedy Heavy Duty Clutch
Aluminum Radiator
Full Body CHARGESPEED Body Kit. (Front Bar Only, Side Skirts, Rear Bar) Side Skirts and Rear Bar to be fitted.
19 Inch Alloy Wheels
Tinted Windows
Alarm
Central Locking
Air Con
Front Mount Intercooler Kit with polished piping.
Edited by Gunzla
https://www.sau.com.au/forums/topic/192767-200sx-series-2-aus-del-17500-neg/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
