Gearbox Gear
Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them. -
Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
By svenskalice · Posted
Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend! -
Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
