Hi!
I`m want boost up my l20et.
I`m buy a watercooled tourbine from VG30DET 15 PSI, and fuel rail with injectors from rb25DE it`s a 270cc?
What i can make with MAF sensor for good work with this setup?
May be make spring in maf harder?
https://www.sau.com.au/forums/topic/192830-l20et/
  • 4 weeks later...
do a search for l20t in the search area...may have what you want there...look first before starting a new thread!
Thank You. I`m use a search and found advice to change L20ET for RB25DE injectors. I`m buy a fuel ramp from RB25DE not a look for it. But i have a some trouble. RB25DE injectirs is side load, my L20ET is up load. :ermm:
Thank you once again :D
https://www.sau.com.au/forums/topic/192830-l20et/#findComment-3532695
Thank You. I`m use a search and found advice to change L20ET for RB25DE injectors. I`m buy a fuel ramp from RB25DE not a look for it. But i have a some trouble. RB25DE injectirs is side load, my L20ET is up load. :P
Thank you once again :rofl:
L20et injectors are low impediance, Look for either the rb25 ones, or vg30et injectors. Before you even think of winding that boost up on a that turbo, intercool her first, Even on the factory turbo a intercooler makes a huge diffrence. Look for my threads and in my signature for mods
https://www.sau.com.au/forums/topic/192830-l20et/#findComment-3534682
