Hey guys,
Sticker on the back it obviously says GTS25 and one cop pulled me over and didnt even check under the hood all he did was check if i tampered with the sticker and he drove off lol.
Im thinking of changing over to a stagea (stock, possibley autech version) but is it easy to tell they are turbo... would i be less likely to be pulled over in a stagea than my non-turbo skyline? Im thinking yes. What are your thoughts?
most cops arn't the smartest cookie's with turbo cars and would most likely be put off as a stagea to being a family wagon. even if your skyline is n/a, you still have more chance as it's a "skyline", and the "skyline" is easy to mod for power.
IMO, the chances of being pulled over in a stagea are somewhere between nill and f**k all (driving style excluded of course)
Earlier this year, we had a Ignition DVD hotspot here in Perth that got completely out of hand. It ended up in the news and started the standard cycle of "hoon" stories on ACA and TT.
I was there in my stag, and about 10pm when the burnouts started me and the missus decided to take off, just as the po po decided to close down all the entrances and do vehicle and license checks on all and sundry. I was in a cue of about 25-30 cars already trying to leave, and I was the ONLY one that got waved through without a second glance. I was kinda put out at the time, because it is my first real "performance" car, but it is all legal and i was looking forward to answering all the standard questions about mah wheelz.
Having said that, there was another WA stagea owner there, and he had to wait until about 3am before the cops took off so he could even start his up, but 600hp awkw JUN motors with bugger all mufflers will do that to you, no matter what car its in (LOL)
G`day DALE i have been STOP about 10 since owning my stagea so i think it`s all about luck,yellow stickered at 9am sunday for darktint,How many stagea are in perth now 30 may be a few more that are not on forum,it`s down to beening lucky.good luck chuckie.
a highway patrol ss stoped next to me today and had a very confused look, as most people do when they see a stagea, i nodded to him and he
nodded back and kept going, it just looks all that innocent.
Ive had the 260 for a few weeks and all i have been gettin from cops are thumbs up :laughing-smiley-014:
I was at a set of lights last tuesday night after work minding my own business, and an angry xr8 driver pulled up beside me and started abusing "jap cars" after looking around i decided to show him what my nice soccer mum car can do and pulled away... come over a hill at about 120 into a RBT, i was in front so i comp breaked down and was waved through, the xr8 driver was immediatly taken to the side and was asked to leave the vehicle, was a good chuckle for me while watching my rear view mirror ;)
go the family wagon!! :happy:
I don't think you'll get pulled over in a stagea unless it has a loud as "f**k off" exhaust or something obviously illegal. Only reason I would see a cop pull you over when you're in a stagea is because they 'don't know what it is'. That's what happened to my dad when he was driving the 4dr 32. They pulled him over because they didn't know what it was. :whistling:
I drive spiritedly but I avoid all the ypical "uleh" hang outs.
Yeah, basically in the last 7-8years of driving grey imports I have much the same story.
If you're not being a knob (excessive speeding, burnouts), hanging out in spots where the police go specifically to book people (because they know you'll be there) and have P-plates (they love you guys, assume the worst), chances are you won't get bothered.... much. Should be alright in a Stagea, having a milo tin for an exhaust and 20" rims probably wouldn't help the cause though.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
