Hello,
I have an HKS GT3037S turbo and wastegate that I may sell, depending upon which car I get next. Just wondering if anyone out there is interested? Not sure what price at the moment. Specs are as follows:
HKS GT3037S Turbo with
56T trim
0.6 A/R Compressor Housing
0.73 Exhaust Housing
HKS External Wastegate (50mm I think)
Cheers!
https://www.sau.com.au/forums/topic/19285-hks-gt3037s-and-wastegate/
Just an update, I actually have 2 GT3037S turbos. One with a 56T trim, the other with a 52T trim. At the moment, the 52T trim turbo is damaged - turbine wheel needs replacing. I am going to send this turbo to Garrett in Sydney to see if it can be repaired. If so, I will sell one of the turbos but not sure at what price, it depends how much it costs me to fix.
I am not sure if I will sell the wastegate as well, because I may decide to keep this. So most probably the turbo will be the only thing for sale. I have a pic of it if anyone is interested, but I don't know how to post pics on this forum?
People interested can email me at: [email protected]
Once again, be reminded that I won't know a price until it's repaired, IF it can be repaired that is. Ball bearing turbos, as you might be aware, are quite difficult to fix. But if you email me, I can send you a pic of the turbo.
GR8NES: The turbos are the same, except the the compressor trim. With one being 56T and the other 52T. I am not sure whether this can be changed, because I don't think you can buy the compressor trims separate. I heard that HKS don't deal with repairs and the likes because it's very difficult to repair and balance their turbos. But Garrett are more willing to help.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
