  • Replies 96
Posted Images
My 33 was originaly bought by a mate, he was tossing up between this one and one with that dash, the only reason he didnt get the one with the dash was because he had never seen one before and thought it would be to hard to replace if something went wrong, tight arse f**ker, i should have one of those now :)
Edited by W0rp3D
  • 1 month later...
does anyone know if this unit would still work with an aftermarket ECU!!!!!!!
yes it does,
im using mine with a powerfc, but you will not get the display unless you have the epson ej1 system and you need the remote too or else you can't change what you see on the dash.
it was only made for the R33
Wow that looks wicked installed! I always thought it looked kinda cheap but when its actually in....
i wanna put one in but wont be able to see the speedo and tacho at the rides with my lil 320mm wheel ;)
lol!
yes they are pretty cool :P its a limited edition nismo dash with the option of sat-nav or epson ej-1 driving emotion system. they are extremely rare, they come up on yahoo-auction very rarely, and the dash normally sell upwards of 60,000yen and then you need to find the epson ej-1 system which can sell upwards of 40,000yen
the epson ej-1 system display information like, speed, rpm, g-force, power, torque, lap time, fuel eco etc etc
here some photo of mine
and some details on all the info it can display
OOOFTt.... that's crazy!!!
i want that now =P
can u do other stuff on it? liek watch dvds and etc? or is it just like the tacho, speed, oil and etc?
Yeah, I have to agree with Police - it is mad, but looks kinda cheap - that's the only let-down but it is awesome.
It's still for sale, grab it if you really want it.
http://cgi.ebay.com/ebaymotors/Nismo-Speed...sspagenameZWD2V
I dunno, the display design looks kinda crappy to me
the display design is like from 1993/1994 so it does look dated. Easy way to solve the problem is to buy a data-logging software or hardware and just hook it into the tv.
you can watch dvd etc if u add the input
Link does not work, this one does tho http://cgi.ebay.com/ebaymotors/Nismo-Speed...1QQcmdZViewItem
And for those wonder, that would be $1,080AU delivered to your door.
Edited by W0rp3D
Carfull
The one you have listed is for a WC34 Stagea, not R33
yes it does,
The Epson EJ1 system, is this an additional item that is required or do R33's have this in them ready to go?
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
