Christmas Sprint Event Wanneroo December 2nd
That's gonna piss you off! How did you go on the track?
Went ok. I just need some new rubber as the old stuff had been heat cycled too many times and had lots its edge. That & a new diff would do wonders. It is all good fun in any case & its not for sheep stations.
This should give everyone an idea of the sorts of cars that turn up - basically anything you can think of!
The thing that sh!ts me to tears is that another half a second would be about, oh 5th. Coulda, woulda, shoulda. But doable, maybe. Unfortunately by the time I find half a second so will everyone else.
I was cleaning up in the shed last night thinking that flushing $50 notes down the dunny may be a cheaper hobby. See the photos for dead brake rotors collection.
Anyway, wait till they get a load of this....
Edited by djr81
Well I thought I was going quick the other night when I ran 1:08, so your doing very well for a street car.
What brake setup are you currently running, as I've destroyed my rotors and calipers :rofl:
Well yes & no. My lap time isn't special. It was mostly done on hp & brakes. Certainly not traction or grip. Hopefully fresh rubber will bring a gain. I had bulk wheel spin on every corner exit. Not productive in any sense.
Brakes: Standard R32 callipers. DBA rear rotors (till they crack, again). Now project Mu front rotors. Ferodo DS2500 pads & motul rbf600 fluid. But I need an upgrade.
Ah, welcome to a world of pain. And expense.
Do I have an answer, well in short no.
The biggest rotor you will reasonably jam in under a 17" rim is 13.5" - 343 in metric speak. But that is dependent on what sort of rim you have. Some will fit, some won't. If it is a Volk/Rays/Nismo/SSR/Enkei you should be ok. Otherwise, probably not.
If you can't fit anything larger than 324 probably just go with Brembos from a 33 R. Do the braided line, good pads, fluid, rotors & remove the stone guards. That will get you 1.1 gees of brakes which is good enough to lock wheels.
Haha, I've been in a world of pain and expense since I bought the Skyline :rofl:
I have Enkei RPF1's, so hopefully I can fit the 343mm rotors. I already have braided brake lines, cut off the stone guards, running Motul RBF600, and had decent pads.
What do you think of the F40/F50 Brembo's ?
Good question.
The only difference between them is piston sizes - with the F50 being larger than the F40. Pad size is considerably larger than the Brembos Nissan fitted to the GT-R's.
I have been tempted to try & find some F40's but they are hard to come by. Biot in Japan no longer appears to list them, instead replacing them with something called a Modena (F360?) calliper. Not sure how the two compare.
I am tempted to suggest maybe finding a second hand monobloc Brembo instead. Don't know from where although there are a couple of GT-R's running them locally.
I don't think I would ever stump up the requisite to buy new Brembo product locally as the pricing is pretty fearsome. If I wanted to spend that kind of coin I would probably go for some AP stuff.
Who do you deal with locally - Perth Brakes?
To be honest I don't deal with anyone locally, considering Race Brakes Perth, seeing as they have a good reputation over east.
Thinking of using the SBC carbon/cermic brake pads. If I can find some F40/F50 calipers then might grab them, if not might plunge into 6pot Alcons.
You did better than you think Richard,the track was very slow on sunday,Sponsors day was the day before and the same cars were much faster.
Ring me and ill tell you a good option for your brakes.Steve Myburge and I have it now and its very good value.
How good is Mike Joss behind a steering wheel?Amazing driver.
Not sure why the track was so slow. It had little grip & strangely absolutely no traction for anyone.
I talked to Steve about his brakes on Sunday so I understand what he has got. Unfortunately I need to buy me some new tyres first. Atleast our bullsh!t carry on on the pit exit gave John Hurney a laugh. Something you don't see enough of.
Yes Mike is a good steerer. As are quite a number of the blokes doing the speedeventseries. The competition is pretty fierce. Drop half a second & you are in the midfield.....
By the way:
http://www.wascc.com.au/Docs/Barbagallo_Ra...nities_2007.pdf
We undecided on brakes for the new 26dett powered 31 , 6 or 4 mmmmm :(
Im happy with my current brake package .. 50 laps of collie in 1 day n no issues , did classic challenge no issues and 2 drivers in Dutton no issues ... NOT 1 cracked rotor or any sign of fade :rofl:
The track was much faster on Saturday for the sponsors day,Strange.
Your car looked to have a bit of mid corner understeer,Did you find that or was I seeing things?May have just been the day but i can see 65s for you soon.
You are dead right. It had more than a bit. But then again the car will understeer when I try & be a hero and attempt to carry too much speed across the apex - so it was as much my fault as the car. It needs a new rear diff to stop the inside rear from bagging up, particularly on the left/right transition going up & over the hill.
Mid 66's (my best effort) & 65's are a different world, but worth aspiring to none the less.
Edited by djr81
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
