is this price right lube mobile quoted me $900 to $1000 to change turbo coolant hose and change thermostat and put new coolant in
also is this the turbo coolant hose it the one with the holes in it
Edited by CHUCKIE821
https://www.sau.com.au/forums/topic/192909-r33-turbo-coolant-line-help/
No idea what mechanics normally charge for that, but i reckon that's a rip off mate. Go get another qoute from someone else.
New coolant change is bugger all. Thermostat wouldn't be more than $50, unless it's like a Nismo item or something. Now for the hose im not sure, but hell a braided line with fittings would only be like $150-$200. So all up i would say around $400 max with labor, depending how they go about changing the turbo coolant line, assuming they take the turbo off it may be a bit more.
But yeah, i still reckon $900 is a rip off, atleast i wouldn't be paying that much.
Hope that helps ;)
i used generic straight hose for that rear water feed from the plenum to the hard line that goes behind the head.
as for thermostat - that can be done by yourself if you are willing. remove bottom rad hose - 3 bolts for the housing. then pry out old thermostat - put sealant on new thermo and put bolts back in.
do a search for a the coolant system bleeding process and follow that - there you go, done for half a day and under $100
