adam,
you can always get a 'proper' performance filter, $100 worth plus adapter fittings. K&N make a washable High flow fuel filter, last time I saw one was at performance unlimited in welshpool.There are other brands of high flow efi filter as well btw. The line size is a little bigger than the stock fuel hose (easy to get a brass adaptor from odin auto's anyway).
Also, when you change the filter you may find part of the fuelhose will crack around the neck of the old filter on either side, so having a little length of efi fuel hose handy will save you some big hassles if you end up short.
i changed it when i first got the car around a year ago but have had the injectors cleaned so thought i might as well do the fuel filter as well as it looks pretty crusty
im not after a high performance one really, just a replacement. ryco list the z201 as their replacement filter for the RB20 was jsut wandering if there was another alternative eg RB30 fuel filter or VG30DETT fuel filter?
so my question should probably read; is the z201 a stock replacement filter
  • 6 months later...
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
