Hey everyone,
I just recently bought my First car a few days ago, :rofl: , and it is an R33 GTS-t Skyline, which i absolutely love :D ,
However, i have a question for the GTS-t owners out there. As its my first car i am a little paranoid
on little sounds and lights which show up, as i want the car to run perfect.
On my dash, as i am driving, occasionally when the turbo is spooling up at higher revs (around 5000ish) a little light flashes on saying "HICAS" , just wondering if anybody would be able to explain it to me, and whether it is a problem or not. I'm not sure whether it has to do with the White Nismo Guage cluster or whether it goes for all R33 GTS-t skylines.
Also if it has to do with mods on the car, i can list them here, although i cant be bothered :-P ... ask if i need 2
Thanks alot in advance, help would be greatly appreciated.
https://www.sau.com.au/forums/topic/192912-r33-gts-t-query/
check out thius thread http://www.skylinesaustralia.com/forums/t113261.html ...i has heaps of basic info on skyline Q's plus answers your Q on HICAS.
basically if you going fast (80k's and over i think) the 4 wheel steering kicks in and attempts to "help" you take corners. ive had it kick in going pretty fast and its a real pain in the ass, basically changes your handling mid turn which can screw you up pretty good.
but yeah check out that thread as there is a big section on HICAS.
https://www.sau.com.au/forums/topic/192912-r33-gts-t-query/#findComment-3464814
Awesome, Thanks alot :-D
btw, peepls, sry bout double forum post, must have clicked twice.
https://www.sau.com.au/forums/topic/192912-r33-gts-t-query/#findComment-3464825
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
