Hmm.
My car seems to want to fry its' back tyres all the time! not that I mind of course :D
Strange quirks.. the passenger door locks when the drivers window gets to the bottom or top of its' travel, pisses the mrs off no end.
It also likes to blow hot air on my feet all the time and have to put it on recirc. whenever I start the car.
when its wet my car doesnt like going anywhere, when i try to drive it just sits there with the wheels going round and when i turn corners the back of the car doesnt want to follow the front of the car
when using the electric window function to go all the way up / down without having to hold the button, once the window reaches it's destination it decides it would like to lock the doors... mostly
Also if i have the air con on for more than 10 minutes straight, it refuses to turn off until i switch the car off completely.
i think they are supposed to lock - mine do it too...
isnt it a safety feature that was used..?
my drivers window goes down when it feels like it.
its embarassing when you are singing along to a song and your window just lowers by itself!
HAhHaHaHA thats well funny... must suck to drive that one around in winter!! its like no0o0o0o ... !!!
LOL
when i use My drivers window going either up and down sounds like a transformer ROFL hell hi tech noise!!
Might want to get that looked at..
Tru, O'm getting new brakes fot it. Not that I shoulxd be doing that on public roads anyway!!
Living up yo ur name then?
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
