These wheels will only fit a GTT with a 5mm spacer on the rear. no guard rolling however and sit perfectly when dropped :ph34r: wont fit a 33 gtst either .. again spacers
I'd buy them and spray them black but im strapped for cash :rofl:
Edited by DECIM8
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490234
Well I have the exact same wheels ( wide pack ) fitted on my R34 GTV ( turbo brakes & suspension factory fitted ) with NO spacers anywhere. So, unless there is a difference between mine and a GTT they should fit. I'll admit that the gap between the rear calipers and the wheels is small, but it doesn't touch :wave:
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490429
I had these wheels also on my r33 gtst. and i didnt use any spacers or anything and it filled the gaurds perfectly. not sure where u got ur spacers ideas from DECIM8? but yes the brakes only just fit behind the wheels which sucks. good luck with the sale.
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3490791
Sorry should of specified.. Series 1 33 it will fit.. series 2 it wont due to bigger nissan writing. R34 GTT will not fit them, Gtv may I have no idea .. GT will.
more power bigger brakes..
Edited by DECIM8
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3491029
Does anyone have a pic of white impuls on a gunmetal R32, ive been wanting some in shadow chrome for a while but if it looks decent in white on a gunmetal 32 ill consider these.
I have a set in normal chrome, that pattern looks good on pretty much all R32's
https://www.sau.com.au/forums/topic/192973-sold/#findComment-3492561
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
