Sorry should of specified.. Series 1 33 it will fit.. series 2 it wont due to bigger nissan writing. R34 GTT will not fit them, Gtv may I have no idea .. GT will.
more power bigger brakes..
I have a S2 33 with these wheels and have no problem with them with or without a spacer!! I run a 5mm slip on all round, as i wanted that look, could even run another 5mm on the front, but would need to roll the lip, which i will do anyways!! I run 235/45/18 all round as i wanted a bit of stretch on the 9.5!! Pic below for anyone that wants to see them in shadow chrome on a S2 33!!
Good luck with the sale, I'm sure they will seel, very popular wheel, almost too much!!
https://www.sau.com.au/forums/topic/192973-sold/page/2/#findComment-3507301
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
