hey guys
ive been searching SDU , SAU
ive got a rsfour stagea that has been converted to a 260RS. wen i take it for a drive it feels like its under load/dragging.
the attessa ecu isnt giving any codes, ive checked the fuses and all good.
ive tryed resetting the ecu via the consult port and leaving the battery off all nite.
now the car hasnt been driven for 18mths while the conversion was happening , and all the brake discs are dirty. should getting them cleaned up and bleeding the system turn the light off?
please help want my car goin by next weekend so i can take it to our agm
thanks
https://www.sau.com.au/forums/topic/192992-abs-light-but-no-flashes/
well don't worry about cleaning up/machining the discs, the first few k of driving will do that for you. Bleeding the brakes is a good idea though.
when the wheels are off the ground do they all turn fairly freely? You could have a sticky piston in one of the calipers. Is unlikely to be electrical related unless it is an attessa problem.
Kind of hard to guess from the description though. What ecu and loom are you running?
  • 3 weeks later...
dude, First things first, are you still running the std brakes or are you running the 260RS brembo's? You haven't said wether the car is stopping OK or not?
start from the end and work backwards.
: As duncan said, don't worry about the discs, they will scrub up OK once you have been driving for a while. Just pretend you are bedding in some hard pads and it will be fine. Just make sure they are not warped.
: Callipers - are you 100% sure you don't have any stuck pistons? Also have a good close look at the callipers slides. I always give these a quick touch up with some 1200 grit wet and dry, a really good clean, and a very light smear of the best high temp grease you can find at pad change time, but if the car has been sitting then any surface rust could be stopping the calliper from positioning the pads properly.
: Pads - It may be worth popping the pads out of the front and have a close look at them. Don't just look for wear, but also for the overall shape of the pad - Are they excessively tapered front to rear (of the car, not the pad)? This may be due to insufficient "knock off" from wrong braking methods, Also, look for shiny spots on the face of the pads - this could be a sign of hot spots (also due to insufficient knock off) All of these will lead to false readings from the abs
: Fluid - Never underestimate the ability of brake fluid to deteriorate. I would drain and flush the whole system one wheel at a time, paying close attention to any difference in pressure from wheel to wheel, if you have any crud built up in the flexible lines it may be restricting return pressure even if it stops OK, leading to some pretty confusing readings for the ABS to figure out.
: Master Cylinder - Check all the obvious things such as vacuum to booster, signs of leakage from the master cylinder, etc etc.
I hope some of my ramblings help, but when all is said and done, it could just be the ecu change......
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
