HONDA CR 250 ,2002 MODEL
AERO PRO TAPER BARS
120 MELVILLE REAR TYRE
DUNE HOPPER PADDLE TYRE USED ONCE
$3900 ONO HAVE SOME RIDING GEAR ALSO IF INTERESTED
IN VERY GOOD CONDITION
PM FOR DETAIL THANKS......
SOUTH AUSTRALIA
Edited by luke james
https://www.sau.com.au/forums/topic/192993-cr-250-motox-2002-3600/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
