You should expect half. Which is generally ~70degree's to ~109degree's.
Operating temp should be around 83-85degree's when using a genuine thermostat.
When you come to a stop the coolant continues to circulate to cool the turbo's; its called thermo syphoning. That is most likely the bubbling type noises you hear.
You should only be concerned if its pushing water oil the overflow.
https://www.sau.com.au/forums/topic/193035-gtr-r32/#findComment-3466035
  • 2 months later...
Not sure exactly for the GTR but bubbling after the car has been turned off is bad, I suspect it's coming from the overflow container? If you could find out for sure it would help. If so then definite cooling system issues.
Cheers,
Matt
I've just bought a GTR R32 & I'm concerned with overheating as I can hear the radiator bubbling after going for a normal drive. The temp guage sits at around half. What should I expect in the way of operating temps?
https://www.sau.com.au/forums/topic/193035-gtr-r32/#findComment-3592486
For the temp gauge to sit around half is normal. But the bubbling sound I have not heard of... Maybe do a radiator flush. Something might be claged up... not sure.
Also use good radiator coolent. I use Techteloy 100, seems to work fine.
https://www.sau.com.au/forums/topic/193035-gtr-r32/#findComment-3593473
Thermosyphoning.
Unless the bubbling is coming from the overflow I wouldn't worry about it and put the noise down to thermosyphoning which is completely normal.
Mine begins a slight bubble 30s-60ecs or so after shut down; its 100% bled correctly and has always done it. All though only a single turbo the principle is the same with twins.
https://www.sau.com.au/forums/topic/193035-gtr-r32/#findComment-3594658
i agree with cubes.
the bubbling sound is quite normal and should well resemble a sound similar to the dying stages of your kettle comming to a boil when making a cup of tea, as essentually, thats whats happening.
my GTR runs a standard temp of arround 75 - 85 degrees depending on weather im driving on highway (cooler) or around town (hotter)
its good you guys are listening to odd sounds comming from your cars and keeping an eye on them, so good work for questioning it - but this one is nothing to worry about :D
Thermosyphoning.
https://www.sau.com.au/forums/topic/193035-gtr-r32/#findComment-3597090
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
