Ok everyone has be telling me for ages that my turbo can't be stock for the power it makes.
I just recently heard some strange noises from the turbo area and decided to pull it off. The rear housing is standard as is the turbine(48mm ceramic). The compressor is 49.5mm top and 64mm lower. I compared it to a VG30bb and the trim on the blades is also different. The compressor cover is also a 45V2 VG30bb unit with slight machining.
Can anyone tell me if the 45V4 rb25 compressor is the same dimentions as the Vg30 or More like mine???? meggala???
Would be good to work out if it has been modified, seems to work very well. If it does turn out to be non standard, I would think a VG30 comp cover and high flow wheel with the same trim would be a very cheap upgrade.
full boost by 2500 to 3000
218rwkw @1bar
225rwkw @1.1bar
I am having it rebuild with a larger VG30 exhaust housing. I will post the result next week after it's finished and dyno'd.
the car came over with a chipped computer and massive fuel filter-go figure. maybe it had a package deal done, I have seen the advertised by tuning shops in japan.
https://www.sau.com.au/forums/topic/19304-12sec-stock-turbo-secret-revealed/
Boosted,
What other mods have you done my goal is around 230Kw at the wheels dont wanna go too far past this as i still want a daily driver and something reliable...
Just wanna know what i need to get it to that kinda power.. slowlu buiding up.. i'll prolly get there in about 10 years though.
paydro,
the kit cost me $400 out of the local trading post. Normally around $1400.
The car will run a high 12 without the Nitrous. Tyres permitting a low 12 with the switch flicked. after I set it up on 50hp a 100hp jet goes in and 11's are on.
sounds very cool to me.
im in the process of upgrading my standard r33 for 12 sec passes but i dont want to use nos yet i want to keep the internals stock as well but planning on using a apexi power fc and avcr boost controller with an obvious turbo upgrade or larger internals.
theres a few other things ive got inmind but ill se how this goes first.
but nos definatley sounds like fun.
p.s. good pick up on the nos
bump
drivebai, performance wise the car has a zaust, filter, cat in pipe, HKS EVC, Power FC, Cold air intake, Greddy front mount intercooler, oil/air seperator, octane booster for 12sec run and a HKS solid centre twin plate clutch. Also running 255 17" on the back.
bump
Boostd thanks man.. i have all those mods except for about 90% of them hehehe so it looks like i will need Power FC, front mount oil/air separator, and hi flow turbo.. basically i need all the expensive stuff... yeah i got 255 17" on the back as well man... I wish you were in Sydney dude.. cos you are pretty much where i am aiming for round 230rwkw... would have been good if you could have taken me for a spin in your car.. so i can see what 230rwkw feels like and compare the differences between my fairly stock crappy car!!!. then i would have more incentive to save.. hehehe.
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
