Model: 1997 R33 GTS-t (Series II)
Milage: 70,XXXkm on odometer
Colour: Sonic Silver
Currently registered? NSW rego till November 2008
Price: reduced to $21,000
Contact: PM or call 0402 33 77 27 (leave a message if I don't answer and I'll call back as soon as possible)
Engine:
Garrett GT3040R ball bearing turbo (0.70 A/R Compressor housing, 0.82 A/R Exhaust housing)
Braided Oil/Water lines to/from Turbo
40mm Turbonetics External Wastegate
HKS low mount cast exhaust manifold
Apexi Power Intake with HP coated intake pipe
Turbosmart Dual-port BOV
Nismo 550cc Injectors
Walbro 255l/min intank Fuel Pump
Z32 80mm Air Flow Meter
Jim Berry 'Full Monty' Carbotic Single plate clutch with 3600lbs pressure plate
Blitz LM Spec Front Mount Intercooler
GReddy Oil / Air Separator
Custom made 3" mandrel bend dump pipe and external wastgate adapter (Castle Hill Exhaust)
Custom made 3" mandrel bend exhaust from dump pipe (Castle Hill Exhaust)
Catco 3" highflow catalytic converter with polished Apexi rear muffler
Splitfire ignition coil packs
Custom radiator air guide
Engine Management/Electronics:
Apexi Power FC Programmable ECU
Apexi Power FC Hand Controller
GReddy Profec B Spec II Electronic Boost Controller
Suspension/Brakes:
Apexi Front Strut Brace
Ferodo DS2500 Brake Pads
Exterior:
Nismo 400R Side Skirts
17" P&W Tracer Shadow Chrome Rims w/ polished lip (8" Front, 9" Rear)
Federal SS595 tyres - 75% tread remaining (235/40/17 Front, 255/35/17 Rear)
Interior:
Brant Nemesis alarm/immobiliser (Aust standard)
Nismo 300km/h dash cluster
Trust GREX Chrome Gear Knob
Window Tints - 30%
Custom Skyline car mats
Custom Leather Gear & Handbrake boots
Audio:
Alpine CD/MP3 Audio Headunit
Boston Acoustic Splits - Front
Boston Acoustic 5" speakers - Rear
Rockford Fosgate 12" subwoofer (boxed)
Rockford Fosgate 4 channel amplifier
Alpine 2 channel amplifier
Performance:
Dyno:
286.4rwkw - MRC Performance, Castle Hill
286.6 rwkw - Unique Autosports, Seven Hills
1/4 mile:
11.9 118mph - Western Sydney International Dragway
Car is serviced without fail every 5,000 kms with full synthetic oil and K&N high quality oil filter. All other fluids replaced every 10,000kms, timing belt has also been replaced. I wash and maintain the car very regularly and it's always garaged when not in use.
Nothing has been left to chance on this car. I bought the car stock standard (aside from cat back exhaust) nearly 4 years ago and have purposely selected and overseen all modifications made to this vehicle. All modifications have been carried out by MRC Performance, Castle Hill using the highest quality components and parts. If something wore out or I thought it needed replacing, I replaced it with the best.
I'm a mature, enthusiast owner who has maintained and treated this car with the respect it deserves. The car has been tastefully modified to ensure it remains extremely streetable, yet moderately powerful. It's never been thrashed on the street (in fact, I've never received a speeding fine in this car), although has the potential to be a big performer on the track as evidenced by the 11.9 1/4 mile time achieved at WSID.
This car will not dissapoint. You could not build a car of this quality for the price I'm asking and you'll go far to find another example in such good condition.
Please call or PM me to arrange an inspection - test pilots need not apply and test drives will only be offered to serious buyers.
https://www.sau.com.au/forums/topic/193064-97-r33-gts-t-series-ii-sydney/
Thanks mate :)
I'll be giving the car it's usual 5,000 km oil and filter change tomorrow morn.
Car is ready for the right buyer - 12 months rego, serviced, nothing more to spend and you get yourself a clean, straight 11 sec streeter
Price reduced to $21,500
I've spent well over this amount in mods and tuning, let alone the value of the car itself. This car is good value for the money - it's straight, reliable, has a tonne of power and doesn't attract unwanted attention. It won't dissapoint :P
32psi geez I would hope u have ur internals done.
Where did you get 32psi from??? :)
Car is tuned on 17psi (as you'd clearly see if you looked at the dyno sheet) which is quite safe on a RB25det.
The top line on the dyno graph (solid red) is the power curve - i.e the primary Y axis (left side) = 286rwkw
The lower line (dotted red) is the boost curve - i.e the secondary Y axis (right side) = 17psi
Cheers Tommo :wave:
I should have another car on the way shortly, so would love to clear out some space in the garage. If anyone is interested, give me a call and make me a reasonable offer. You never know your luck, the worst thing I can say is no...
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
