Make:Nissan
Model:Cefiro
Milage:200000km
Colour:Black
Currently registered until 30/06/08
Price:$9000 ono
Contact:Sam 0430040919
Veilside Andrew V rims, 17x7.5 inch front / 17x8.5 inch rear
Walbro fuel pump
Front strut bar
Hicas Locking bar
Timing belt and front oil seals replaced and full service 1000km ago
Motor replaced with 55,000km engine from SSS automotive a year ago.
Adjustable rear upper arms
New HKS air filter pod
New clutch
No oil or water leaks
Turbosmart duel stage boost controller
Full 3 inch exhaust with stainless split system dump pipe, high flow 3 inch cat, and mild steel catback with 4 1/2 inch tip cannon
JVC CD player, kenwood front speakers, MTX rear speakers, Pioneer sub, Alpine amp
Fully engineered for these mods plus TEIN coilovers and Recaro drivers seat. (Could add them legally).
Good reliable car, has been my daily driver for close to a year
https://www.sau.com.au/forums/topic/193086-cefiro-rb20det-factory-manual/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
