Hey ever 1 atm i have an r33 Gtst s1, an have $20k to spend if i choose on it (YEAH). The car atm is completly stock excluding a exedy heavy duty clutch. was thinkin off the followin mods....
GT30R
Hybrid FMIC 600+300+75
Full custom 3.5in S/S Exhaust
Bosch Fuel Pump
720cc injectors
hks cams an camshaft
Avc-R
Apexi Power Fc
HKS SSQ Blow of Value
K/N Pod
With a tune???
Would this be enough runnin probable 20psi to bring me around the 280-300rwkw mark safely?? or would more bottom end work be required to keep safe??? An would $20k get me the above mods??
Thanks Cliffo
https://www.sau.com.au/forums/topic/193190-20k/
you'd be better off selling it and buying a 33 that was already modified
unless you absolutely have to spend the extra money for the sake of being able to say you built your own car
Well i really do wanna modify it myself so that was why i bought a stock line in the first place, for personal pride.. But i can see where your coming from.
https://www.sau.com.au/forums/topic/193190-20k/#findComment-3468553
Buy one already done, yes it's fun to do your own but its a waste money that can be spent on better things. There is an abundance of full built 300-400rwkw gtst's on the market at the moment and plenty around 20k and cheaper and some really nice cars in excellent condition. Change it aesthetically ie wheels bodykit etc and its personalised and a damn site cheaper without all the headaches. That way you drive it and enjoy rather than wait, fix change etc.
https://www.sau.com.au/forums/topic/193190-20k/#findComment-3468593
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
