Manual or Semi-auto
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi guys,
Thank you all for voting in my previous thread on selecting the right car.
I have made up my mind on the Evo 10.
Initially, I would have wanted a manual.
However, my parents want me to get the semi-auto. They think its better to drive and will have better resale value.
If you were getting the evo x, which transmission would you get?
Please place your votes above.
Luv u guys.
Dr Dan
Edited by danieltangtc
yeh i think their semi-auto box is like the vws and audis, DSG, you can hardly feel the shifts but its an awsome drive. Id say semi auto but then if you wanted to take it to the track maybe a manual?
edit: good choice on the car btw :P
Edited by vinnie34gtt
its not an auto, its a dgs... ie clutchless manual. when in auto mode it uses shift logic, when in "manual" mode it should not change at all unless you tell it to engage.
google DSG for indepth information.
If it is a road car then the DSG gearbox is far more superior than a manual.
If you plan to track or rally the car then a manual will be a better choice.
Listen to your parents, they are correct and if there is any problem, it has a 5 year warranty.
How do you guys find the DSG transmission in the Audi/VWs?
I have never driven one before.
Also, if I were to sell the evo in future, which would sell better? DSG or 5spd manual?
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
