Manual or Semi-auto
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi guys,
Thank you all for voting in my previous thread on selecting the right car.
I have made up my mind on the Evo 10.
Initially, I would have wanted a manual.
However, my parents want me to get the semi-auto. They think its better to drive and will have better resale value.
If you were getting the evo x, which transmission would you get?
Please place your votes above.
Luv u guys.
Dr Dan
Edited by danieltangtc
yeh i think their semi-auto box is like the vws and audis, DSG, you can hardly feel the shifts but its an awsome drive. Id say semi auto but then if you wanted to take it to the track maybe a manual?
edit: good choice on the car btw :P
Edited by vinnie34gtt
its not an auto, its a dgs... ie clutchless manual. when in auto mode it uses shift logic, when in "manual" mode it should not change at all unless you tell it to engage.
google DSG for indepth information.
If it is a road car then the DSG gearbox is far more superior than a manual.
If you plan to track or rally the car then a manual will be a better choice.
Listen to your parents, they are correct and if there is any problem, it has a 5 year warranty.
How do you guys find the DSG transmission in the Audi/VWs?
I have never driven one before.
Also, if I were to sell the evo in future, which would sell better? DSG or 5spd manual?
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
