Get a new belt, could be just dry and old.
Depends on the load on the vehicles circuit, cant imagine why the non turbo is higher but you can burn out the voltage regulator... eventually (I really wouldnt worry it) maybe even your coilpacks?
Shouldnt be an issue until you turn everything on, i.e. stereo, air con, headlights etc. even then you can measure the load accross the battery terminals to make sure its ok.
if anything your lights may dim every time your sub is kicking etc. maybe even stall...
everything seems to be fine witht he new alternator, including when stereo is on lights etc. NOw my next project is installing the apexi full auto timer, does anyone have any tips or DIY tutorials on this, i would really love them!! please link or post up what you have!
Ahh excellent, well there hasn't been a problem with the alternator yet, car runs fine, no squeals so i happy with it.
I have heard that HKS turbo timer harnesses are compatible with Apexi, is this true i have ordered one for my apexi full auto timer and i hope it fits as i have already paid for it! dammit! anyhow..any thoughts/ideas on this would be great.
HEY there guys if any of you want to know how to install the apexi full auto timer here is my tutorial, http://www.skylinesaustralia.com/forums/In...89#entry3491589
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
