Make: 1988 Ford KE Laser (Automatic)
Milage: 220000
Colour: red
Currently registered? expires 10/2008
Price: $700 ONO
Contact: Kirby 0421763988
Just wanting to sell my daily run-around. Its has 11 months rego and is running well. Havent really had any major mechanical problems with it, replaced the left CV about a month ago. The paint isnt in very good condition, some panels are faded and the interior is in average condition. But if that doesnt bother you its a good option for a daily run-around. In regards to the price i just want to get back what i paid for rego... and hopefully a little bit more. So feel free to throw me an offer.
Edited by Kribside
https://www.sau.com.au/forums/topic/193246-fs-1988-ford-laser-700/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
