1. will feel slightly less boaty, handles better, wears out the standard shocks quicker
2. unlikely unless you have massive wheels with an offset hanging out the guard
3. best? coilovers; cheap? have your standard springs compress
Edited by vietorious
https://www.sau.com.au/forums/topic/193270-lowering-my-r33/#findComment-3468889
cheap, get a angle grinder and chop a coil off the standard spring hahaha
what you budget?
best would be coilovers like already said, if you only want to spend 2-3hundred get a set of kingsprings or the like and install them
https://www.sau.com.au/forums/topic/193270-lowering-my-r33/#findComment-3469162
At moment im spend like 6g on the car, on a turbo upgrade
So money is like scarce....
Eventually i want coilovers
Everyone is saying to Drop the car and inch
but i wanna aske people who have done this before
is the pros or cons to this
https://www.sau.com.au/forums/topic/193270-lowering-my-r33/#findComment-3469331
so all you need is a set of lower springs? like around $250? thats it??? no new shocks, camber kit etc???
https://www.sau.com.au/forums/topic/193270-lowering-my-r33/#findComment-3470471
go to group buy section and get the bilstein shocks and whiteline springs
actually - prob be out of your budget if you are spending all the money on power as I think they work out 1200 delivered
https://www.sau.com.au/forums/topic/193270-lowering-my-r33/#findComment-3470514
I will probably get the sydney kid pack.
but atm i just need it to inch lower
https://www.sau.com.au/forums/topic/193270-lowering-my-r33/#findComment-3470535
