I have seen a car in japan that had R34 attesa and ABS fitted (along with a 34 engine and 6 speed too).
if I was going to do it I would skip the 33 and go straight for 34 if at all possible.
I heard ages ago that you could just swap the controllers, did a 1 minute google and came up with;
http://www.gtr.co.uk/forum/upload/6095-r32...controller.html
which refers to this
http://www.carsurvey.org/review_19225.html
Which says "Unless you know what you're doing you'll be better off with an R33 or R34, but for the ultimate in more than one sense of the word, an early R32 is hard to beat.
Handling can be subdued considerably by swapping in the ATTESSA-ETS AWD controller unit from R34, which pretty much makes the car behave like its newer counterparts."
  • 5 years later...
I just ended up getting the cheapo ebay attessa tweaker, and it worked so well i just left it at that. The plugs are different on the attessa units, so its more than just a simple brain swap. No idea how much more.
They work well yes, but you're only ever going to get the system to operate as fast as it's weakest link.
I think it could be worthwhile, I am sure someone has done it.
Just need to do some dredging.
It's funny for how widespread the internet is there is still alot that only exists in the real world and I'm ok with that I think.
For me, i'd want to have some evidence it will make a non-trivial improvement over a tweaked standard system for the effort to be worth it.
But you may just want to satisfy your curiosity and try it!
Driving an R33 GT-R and 33 Back to back clearly shows the worthiness of the AWD upgrade I think.
ETS-PRO while good like the Ruzic unit is still not going to the root issue which is the preload, the speed at which the system operates and of course the vast increase in sample rate.
ETS-Pro maintains preload, the R32 and R33 system are same operating speed (pump gaining and losing pressure) and it has a brand new ECU with much faster sample rates?
I guess you meant R32 and R33 GTRs? If so, thats pretty obvious and therefore not so interesting.
IMO what is more interesting would be comparing an R32GTR+attessa tweaker to an R33GTR without a tweaker.
I'm assuming that the change in front/rear bias as the system evolved is a much more significant affect than things like the ECUs sample/clock rates. It is an assumption tho. Would be interesting to KNOW. Bang for buck and ease of installation the tweaker will be miles ahead.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
