Hi All,
I need your help. I want to buy these rims but im not sure if they will fit my R33gtst because of the calipers.
The size i want to get are:
Front = 17 x 7.5 +40
Rear = 17 x 8.5 +40
I cant understand on the rays site if these rims will fit my car or if my calipers are too big on the front. PLEASE HELP!!!!
https://www.sau.com.au/forums/topic/193335-nismo-lmgt4-rims/
id say yes to if your breaks are stock..cant imagine that you would need offset so positive tho, i think they only make the Lmgt4's in +15 +30 +40 so i would be picking from one of the other 2 offsets.! good luck with the wheels mate.
standard offset on the stock rims is +38, so +40 will fit and if your brakes are stock it wont hit. Although personally, i would go the +30 offset to have more flush with your guards, the tyres wont be outside your guard but it will just make the stance look a bit tougher imo.
The +15 offset is along the lines of a gtr and you'll have a far bit of the rim outside the guard which is no good
Edited by R34GTFOUR
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
