I think one of my AFM's is on the blink.
I am going to turn my ECU on to diagnostic mode but I can't get my hands on a list of the codes - does anyone have them?
Also - once I turn it into diag mode am I correct that the ECU will use the exhaust temp light on the dash to communicate the error codes?
https://www.sau.com.au/forums/topic/193343-32-gtr-error-codes/
Would rb20 codes be same as gtr?
Here's a list if it is :)
Diagnostic for the rb20det ECU
The ECU is in the passenger footwell, behind the plastic kickplate to the left of your feet. You'll have to remove the computer from the mounts in the footwell, as the led/leds you'll need to see are pointing towards the front of the car. Switch on the ignition but don't start engine, the led on the ECU will begin glowing turn the selector screw clockwise all the way.
There's three types of factory ecu in Skylines, One type has two LEDs and five modes, the other type has one LED and two modes and the last type has no LEDs, the output is done with the engine check light in the instrument cluster.
For two led ecus the led will flash once, pause, flash twice, pause... all the way up to five this is the diagnostic mode Mode 1 = one flash, mode 5 = five flashes. When you reach the right mode, turn the screw back counter-clockwise. Mode 3 is what most people use.
For one led ecus wait a couple of seconds, and turn the screw back counter-clockwise, the ECU is now in mode 2 the engine check light on the dash will mirror the LED on the computer.
The led will flash out a code or series of codes if there is more than one fault More recent ECU's have two LED's red is first digit, green is second digit, eg red 2x flash, green 1x flash = code 21. The ecus on most R32's have one LED, long flash = first digit, short flash = second digit, eg long, long, short = code 21.
Codes:
11 Crankshaft position sensor
12 MAF sensor circuit
13 Coolent temperature circuit
14 Vehicle speed sensor circuit
21 Ignition circuit
31 ECU
34 Knock sensor
43 Throttle position circuit
45 Injector leak
51 Ignition circuit
54 Auto signal to ECU
55 All OK
Turn the ignition off to put the ECU back to normal.
There is also a O2 sensor test in real time available - do the above to get the ECU into mode 2 (single LED ECU) or mode 1 (2 LED ECU's) Start the engine. Warm the engine, and then run under no load at 2000 rpm for the test. Single LEDs: on = lean, off = rich Dual LED's: green LED on = lean, green LED off = rich
Remove the speed limiter:
Cut wire #53 on the ECU harness to disable the 180 kph speed cut. The wire is yellow/green with a silver trace. Insulate the bare ends with tape. There has been talk that this effects the hicass, but from what i've seen posted around the net driveability of the car is not changed.
*Warning*
If you cut wire #53 all it does it prevent you from exiting the HICAS DIAGNOSTIC mode… Its therefore better to place this speed cut on a switch so you can still exit easily.
rb20det eccs control unit pin layout.
1 Ign signal (power transistor) Cyl #1
2 Ign signal (power transistor) Cyl #5
3 Ign signal (power transistor) Cyl #3
5 engine. A/T control input signal (bt1)
6 Sub electrical fan relay (engine temp switch)
7 Tacometeter speed signal
9 AC relay (AC cut signal)
10 Ground (ign signal system)
11 Ign signal (power transistor) Cyl #6
12 Ign signal (power transistor) Cyl #2
13 Ign signal (power transistor) Cyl #4
14 engine. a/t control input sigal (bt2)
15 engine. a/t control input sigal (bt3)
16 ECCS relay
18 fuel pump relay
19 Power steering switch
20 Ground (ignition signal system)
21(RX) Receive (control unit data reception)
22 (TX) Transmit (data sent from control unit)
23 Detonation sensor 1 (cyl 1-3)
24 Detonation sensor 2 (cyl 4-6)
26 Air flow meter ground
27 Air flow meter intake air quantity signal
28 Engine temp sensor
29 Exhaust gas sensor
30 Sensor ground (throttle sen, ENG temp)
31 clock (synchronization signal)
32 Monitor and check lamp (red)
38 Throttle opening output
41 Crank angle sensor (120degree signal)
42 Crank angle sensor (1 degree signal)
43 Ignition switch START signal
44 Neutral switch
45 Ignition switch (IGN)
46 AC switch
47 (CHK) Check (diagnosis activation)
48 Throttle sensor power supply
49 Control unit power supply
50 Ground (control unit)
51 Crank angle sensor (120 degree signal)
52 Crank angle sensor (1 degree signal)
53 Vehicle speed sensor
54 Throttle valve switch (idle connection pt)
56 Throttle sensor output signal
57 Throttle valve switch power supply
58 Battery power supply
59 Control unit power supply
60 Ground (control unit)
101 Injector #1
103 Injector #3
104 Fuel pump terminal voltage control output
105 Injector #2 107 Injector ground
108 Injector ground
109 Injector power supply
110 Injector #5
112 Injector #4
114 Injector #6
115 exhaust gas sensor heater ground
116 injector ground
  • 3 months later...
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
