Make:Toyota
Model: Corolla Seca Twin Cam 16
Milage: 2020000
Colour: Faded and peeling red
RWC supplied? not required
Currently registered? Yes Till August 2008
Price: $2200 with 17" ROH Adrenalins or $2000 with stock S1 alloys with 2 G-grid tyres and 2 bald retreads (will fit 2 tyres for extra $100)
Contact: Sam on 0413728316
Item Condition: Fair, does have rust in the rear quarters and front door apetures, Interior Carpet is marked but seats are in great original condition. Mechnaically Sound. Lower Engine Mounts need replacing (May replace depending on negotiations) paint is faded
Engine: 4AGE Bigport with approx 140k - Runs well.
Gearbox: C52 5 Speed Manual
Since Purchase i have replaced:
Engine with 88model motor with ~140k
Front Control arm bushes
17" ROH Adrenalin Alloys (optional)
Radiator
This is a great sound 1st car or as a daily runabout as i have used it. Lots of rego
Pics of the build can be seen here
Images:
Contact Details: Sam on 0413728316 email samuel(dot)mitchell(at)optusnet.com.au
https://www.sau.com.au/forums/topic/193366-for-sale-1986-toyota-corolla-seca/
  • 4 weeks later...
  • 4 weeks later...
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
