Mine already has HID's on them but i just want to change them to more of a blue HID head light, cuz at the moment the HID's look just super white with alittle bit of blue in them.... So what do i have to replace in my case? just the bulb?
  • Replies 42
i have no idea why i didn't think about this, but is there anything stopping us R34 owners with Xenon assembly's, but hacked due to compliance, from getting D2R kits and get an OEM light output?????
I thought i wrote this idea off for some reason, but can't remember why....
I don't see why not. As long as the ballast and globes are good quality it should be fine as far as I know.
"auto group buy" he can supply me HID kit with D2R globe!!!
is bosch good brand? other than kaixen or phillips and hellar?
If I were you and could get some bosch items over the cheapo ones on ebay, I'd get them. I just think of it as, "If I know what the brand is, it must be good." haha, if it's some random company, then it's probably shit.
You just need to replace the globe with a higher kelvin. I think standard would be 4300K which give the best, whitest light. If you want a blue to it, you should get 6000k, but I don't know if they make them at this temperature for the D2R's.
Don't get the 6000k in my opinion. They look too ricey and you'll get a much higher chance of getting pulled over with them. Stick with the 4300k.
R33 Turbo you only need to change bulb if you have HID kit already installed. 6000k is more bluish. Haines posted a pic in my section as he ordered D2R in 6000K and see the difference in light.
Tyaos, Philips and Bosch are top quality brands but to compare may be check HIDplanet.com and post there to get opinion. i've never tried Philips but i heard they are really good as well.
yes phillips are really good but really expensive..
i probably go with bosch! you gurrantee the quality of product auto gourp buy???
please show me your confidence!!! LOL
anyway is rockdale is around airport right?
give me your address and ill go there after exam or before... it will going to be on saturday though
Thanks
paul
Thanks
paul
Hi Paul,
It comes with 1 year dustproof and waterproof manufacturer warranty. Lot of people installed and i didn't have any negative feedback from anyone yet :-). 666DAn is right please check your bulb before ordering to see if the sockets are not played around by compliance. Do you have D2R bulb right now in your car? PM me when you're ready. I'll have to order the kit since i don't keep in stock and takes 3 days from day we receive payment for kit to be available. Yup rockdale is near airport.
Cheers,
Manu
Hi Paul,
Cheers,
Manu
no i dont have D2R globes in my car.. will the kit comes with D2R globes right?
ill let you know when im ready!!
thanks!
paul
What globes do you have now in your car? Check the back of the globe. If you don't have D2r now chances are D2R won't fit. Let me know what bulb you've when you're ready to order.
Kit comes with 2 ballasts, 2 bulbs and necessary wires and sockets.
Cheers,
Manu
Sorry i just checked your post before that you got H1 bulb currently. Why don't you go with H1 HID kit then? I think you can install D2R as well but you'll need extra wiring and socket because D2r doesn't come with sockets and wires.
The H1 globes aren't designed to suite his headlight housing because they were made for D2R globes. He wants to get the factory light output. All the H1 globes are going to do is cause glare and hot spots. Just as bad as 33's with HID kits.
Tyaos, so sorry mate, but that's what i forgot to tell you.
Compliance puts this metal piece in the socket for where the globe sits to make it fit an H1 globe. So basically, the sockets for the H1 globes in our headlights can't take D2r's at the moment, we have to remove the metal piece they put in.
AFTER that, we can go nuts on the D2R kits. That's what i was saying to you via PM that i remember there was something stopping me from just going straight back to D2R but couldn't remember what. That "something" is the metal piece they insert in the socket.
It's glued or welded in there, and i have a feeling we'd have to take the headlight apart to get to it.
666DAN: You're one of the ultimate handy-men when it comes to 34's, would we need to oven our headlights to take the H1 insert out??
cheers,
daniel
actually the metal part in my headlight is very loosened...... the compliancer was must've been lazy..actually its like an adpater....i was wondered what the hell is this when i changed my light bulb when it was bursted.. anyway as long as its been loose and easy to take it out (its not even easy, if i pull the light bulb out it comes with it...-.-;; lol)
i can possilbly install D2R without any modification right?
thanks guys
horray~yes!!
i think ill be fine with D2R!!!
ill be check with one of the auto electrician to make sure and ill let you know manu!!!
Thanks guys!!!
Adam and 666Dan you guys helped so much since i joined this forum! thank you!
cheers
paul
Hi beam wasn't even Xenon from factory as far as i know? You can only really have hi beam Xenon with is always on with lo beam, but a shield use to block the hi-beam light until you need it. Xenons don't really flick straight on like halogens, so hi-beam is a slight different story
Yeah, I was going to say something like this. It's not recommended that you flash HID globes on and off quickly. With the high beams, that's what you're pretty much going to do. I don't see why Nissan used HID's for the high beams. The other car's with HID high beams have high and low beams in the one projector with a shield like you mentioned.
horray~yes!!
Thanks guys!!!
cheers
paul
No worries mate. :wave:
Edited by adam-__-
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
