Mine already has HID's on them but i just want to change them to more of a blue HID head light, cuz at the moment the HID's look just super white with alittle bit of blue in them.... So what do i have to replace in my case? just the bulb?
  • Replies 42
i have no idea why i didn't think about this, but is there anything stopping us R34 owners with Xenon assembly's, but hacked due to compliance, from getting D2R kits and get an OEM light output?????
I thought i wrote this idea off for some reason, but can't remember why....
I don't see why not. As long as the ballast and globes are good quality it should be fine as far as I know.
"auto group buy" he can supply me HID kit with D2R globe!!!
is bosch good brand? other than kaixen or phillips and hellar?
If I were you and could get some bosch items over the cheapo ones on ebay, I'd get them. I just think of it as, "If I know what the brand is, it must be good." haha, if it's some random company, then it's probably shit.
You just need to replace the globe with a higher kelvin. I think standard would be 4300K which give the best, whitest light. If you want a blue to it, you should get 6000k, but I don't know if they make them at this temperature for the D2R's.
Don't get the 6000k in my opinion. They look too ricey and you'll get a much higher chance of getting pulled over with them. Stick with the 4300k.
R33 Turbo you only need to change bulb if you have HID kit already installed. 6000k is more bluish. Haines posted a pic in my section as he ordered D2R in 6000K and see the difference in light.
Tyaos, Philips and Bosch are top quality brands but to compare may be check HIDplanet.com and post there to get opinion. i've never tried Philips but i heard they are really good as well.
yes phillips are really good but really expensive..
i probably go with bosch! you gurrantee the quality of product auto gourp buy???
please show me your confidence!!! LOL
anyway is rockdale is around airport right?
give me your address and ill go there after exam or before... it will going to be on saturday though
Thanks
paul
Thanks
paul
Hi Paul,
It comes with 1 year dustproof and waterproof manufacturer warranty. Lot of people installed and i didn't have any negative feedback from anyone yet :-). 666DAn is right please check your bulb before ordering to see if the sockets are not played around by compliance. Do you have D2R bulb right now in your car? PM me when you're ready. I'll have to order the kit since i don't keep in stock and takes 3 days from day we receive payment for kit to be available. Yup rockdale is near airport.
Cheers,
Manu
Hi Paul,
Cheers,
Manu
no i dont have D2R globes in my car.. will the kit comes with D2R globes right?
ill let you know when im ready!!
thanks!
paul
What globes do you have now in your car? Check the back of the globe. If you don't have D2r now chances are D2R won't fit. Let me know what bulb you've when you're ready to order.
Kit comes with 2 ballasts, 2 bulbs and necessary wires and sockets.
Cheers,
Manu
Sorry i just checked your post before that you got H1 bulb currently. Why don't you go with H1 HID kit then? I think you can install D2R as well but you'll need extra wiring and socket because D2r doesn't come with sockets and wires.
The H1 globes aren't designed to suite his headlight housing because they were made for D2R globes. He wants to get the factory light output. All the H1 globes are going to do is cause glare and hot spots. Just as bad as 33's with HID kits.
Tyaos, so sorry mate, but that's what i forgot to tell you.
Compliance puts this metal piece in the socket for where the globe sits to make it fit an H1 globe. So basically, the sockets for the H1 globes in our headlights can't take D2r's at the moment, we have to remove the metal piece they put in.
AFTER that, we can go nuts on the D2R kits. That's what i was saying to you via PM that i remember there was something stopping me from just going straight back to D2R but couldn't remember what. That "something" is the metal piece they insert in the socket.
It's glued or welded in there, and i have a feeling we'd have to take the headlight apart to get to it.
666DAN: You're one of the ultimate handy-men when it comes to 34's, would we need to oven our headlights to take the H1 insert out??
cheers,
daniel
actually the metal part in my headlight is very loosened...... the compliancer was must've been lazy..actually its like an adpater....i was wondered what the hell is this when i changed my light bulb when it was bursted.. anyway as long as its been loose and easy to take it out (its not even easy, if i pull the light bulb out it comes with it...-.-;; lol)
i can possilbly install D2R without any modification right?
thanks guys
horray~yes!!
i think ill be fine with D2R!!!
ill be check with one of the auto electrician to make sure and ill let you know manu!!!
Thanks guys!!!
Adam and 666Dan you guys helped so much since i joined this forum! thank you!
cheers
paul
Hi beam wasn't even Xenon from factory as far as i know? You can only really have hi beam Xenon with is always on with lo beam, but a shield use to block the hi-beam light until you need it. Xenons don't really flick straight on like halogens, so hi-beam is a slight different story
Yeah, I was going to say something like this. It's not recommended that you flash HID globes on and off quickly. With the high beams, that's what you're pretty much going to do. I don't see why Nissan used HID's for the high beams. The other car's with HID high beams have high and low beams in the one projector with a shield like you mentioned.
horray~yes!!
Thanks guys!!!
cheers
paul
No worries mate. :wave:
Edited by adam-__-
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
