Ok guys if you know anyone that wants a skyline tell them about mine, as its really got to go!!! I know I told some of you I was now keeping it but I just cant afford to, so the car must go. I have dropped the price to 16k for a quick sale. There is a case of beer or fav drink in it for the person who directly helps.
http://www.skylinesaustralia.com/forums/Sa...97#entry3470697
failing next couple of job interviews I am applying for work in sunny Brisbane so car really has to go.
Edited by race_snooze
https://www.sau.com.au/forums/topic/193402-car-must-go/
getting desperate here more and more bloody bills lol..., (at this stage there will be no toy to replace it either) can you guys give me some hints to sell this thing I am pretty sure the price tag is very reasonable for this toy too if its not then tell me.
Thanks guys, oh and in the next 2 to 3 years I do plan to buy a r34 to replace her.
https://www.sau.com.au/forums/topic/193402-car-must-go/#findComment-3482278
The fact you have had it on so long now snooze i think you may be in some trouble in that...
- There seems to be a lot of people selling modified cars all at pretty good prices
- Most people still have the idea in there heads if the cars stock/stockish it's been looked after and not thrashed.
- Me personally if i was to buy a modified car i would be getting one that is heavily modified eg forged internals, massive turbo etc etc.
I think you really have to two choices...
1 - Ride it out as maybe the right person has not come along yet.
2 - Strip off the parts that are worth a fair bit of money and return it to stock performance wise. The kit i think would be a big + but if you can sell your turbo, injectors, coilovers, fmic, wheels and a few other goodies you might get $3000 - $5000. Spend maybe 500 - 800 getting the stock parts and then sell your car for like 12 - 13 which would be more suited to the cheap people out there.
https://www.sau.com.au/forums/topic/193402-car-must-go/#findComment-3482845
I really have to get my sh*t together as well... I'm not too fussed with having two awesome cars in the garage but its just not practical.
If anyone who knows my car and knows someone shopping for one then hit me up. I'll get my pics and stuff sorted soon...
Hope you dont have too much more trouble with it mate. Let me know if you need a hand with anything.
https://www.sau.com.au/forums/topic/193402-car-must-go/#findComment-3482933
Hey Leigh I have been contemplating that exact idea of putting it back to stock I have most of the parts, would need some coil overs, front and rear bars, stock side mount, rims, and turbo. Then run into the fact I dont really have the time, see what happens.
Cheers
https://www.sau.com.au/forums/topic/193402-car-must-go/#findComment-3483041
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
