I have an R32 GTR with R34 N1's, PFC, Blitz Dual SBC and lots of other stuff. It recently got tuned by Jim at CRD and made 285 AWKW @ 20psi. (Jim said his gauge was only showing 17 but it showed 20psi on my gauge on the street.)
After a trip home from Sydney I noticed that by my gauge I was only running 15psi and not 20 any more. I had not touched the boost controler or anything else. The PFC handset use to show about 1.35 to 1.4 bar when the gauge showed 20psi. Now at 15psi on the gauge it still shows about 1.28 bar on the handset. I tried to turn the boost up at the controller to see what sort of control I had but it required a big increase at the controller to get a small increase on the gauge. It didnt really want to go over 17-18 on the gauge.
So, at first i thought it may have been a leaking cooler pipe so i checked all them and they are fine now. I then removed the 'out' hose from the boost control solenoid in order to basically stop the controler from controlling the wastegates. This resulted in the turbos spinning freely to 20psi on the gauge where I back off. So from this i take it I can rule out a leak or a stuffed turbo ?? The strange thing was that the PFC hand controler showed 1.6 bar peak hold at 20psi on the gauge, when it use to only show about 1.4.
So I have a few problems here I think.
How did I loose 5psi on the gauge??
Does it mean my boost controller is playing up because when it is conected to the gates it wont allow over 15psi ??
Why is the PFC showing me strange and inconsistant figures ??
Any help with this would be great.
Thanks.
Tim.
Edited by R32 Zilla
https://www.sau.com.au/forums/topic/193444-loss-of-boost-in-32gtr/
well it's quite possible the guage is faulty. also, with so many connections t'd off the one source you are in for a work of trouble. personally I'm not a fan of t'ing anything at all into the fuel reg pressure feed. as if something goes wrong with it you are heading for a massive lean out as soon as you hit boost. not good.
Ok Iam trying to find another vaccum source to T in a few things. I have 4 things that need vaccum. The PFC, boost gauge, boost controler and fuel presure reg. I cant seem to find any other source other then the one iam using now. I tried one that was close to the one iam using at the front of the motor but it hardly registered anything on the gauge. So where does everyone plumb in all these things ? If I could find just one more source then I could plumb 2 things into each source.
Thanks
Tim.
There must be a simple explanation for this.
The vacuum sorce with little signal im guessing would be the one off the front throttle plate for the canister, which only works when the throttle is open.
Just take it back to CRD and get them to have a look. You stuffing around with it will most likely cost you more money because CRD will have to put it back right and you might even hurt something in the process.
Oh, and how does your PFC use the boost source when youve got the SBC?
The PFC must use the boost signal only for the boost reading on the handet ? I am not sure.
I have found another vacuum source at the rear of the motor. It is only small in diameter and it runs to a small unit on the firewall. Could this be used at all ?
I wish I could just take it back to CRD but it isnt that easy for me just now. I am spraypainter not a mechanic but I can normally sort through things like this.
Tim.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
