you dont have to have stretch and massive camber for good fitment
put up a picture of your car so I can have a look...
http://img295.imageshack.us/img295/4612/75265928sl5.jpg
http://img264.imageshack.us/img264/340/72821498bk1.jpg
Pretty much flush.
  • Replies 76
you need 10mm to 15mm spacers to achieve teh flush :w00t:
just sayin
that said... somoene who has drifteks and bags out people who rock stretched tyre tucked wheel fitment is kind of throwing rocks in a glass house.
bah people who follow one school of thought will not understand the other, and it always turns into a shitfight. the fitment we're talking about is form over function as far as traction is concerned... but its far from impractical.
I like this thread, It has taught me something new...I honestly thought the cars I'd seen with stretched tyres on huge rims irl were that way because they couldnt afford the right size or find the correct fitment for the rim or were just making do with what they had ect. Kinda made me feel sorry for them.
No shit I did!
If thats the image/look you're after goodluck to you, no harm in that.
Myself I hate subs/bodykits or any bling that adds weight to the car without giving more than it's weight in returned Kw's, I'd never put looks over performance or safety, Clean straight and light..but thats my thing.
Big ups to funkymonkey for finding a new way to use the word stigma, I never knew a stigma could be something to aspire to.
Edited by madbung
meh... rat rods in the US were also an abomination, frowned upon by society, most often associated with organised crime, ie. a stigma and look at it now... people pay thousands for a properly done rat rod, and the kind of words people use to describe em aren't exactly negative. There's not much about them that is practical... a very similar situation to this practice of stretching tyres and tucking wheels.
Where down the track did we loose sight that modding is a personal prefrence more so than ragging on other peoples rides..
Arogance is something that I see too much of in the scene and is just as sad to see as baby rabbits dieing..
But dude, its not flush...
Back wheels maybe almost, but the fronts are far from flush!!
agreed
at least another 15mm of spacing required on the rear to acheive flushness and its too high also
but thats just my opinion
  • 3 weeks later...
anyone else wona show us some pics of their stretched bits and tell us what type an size of tire and width of rim they are using??
im was running 205 on my 8inch wide rims (17x8j +38), no pics as i destroy the tyres at the last drift practice, i will be getting some new tyres soon 205 again, as funkey said too poor to go bigger lol, then i will take some pics
edit the tyres were just some cheapy secondhands cant remember the brand
Edited by [Michael]
okay so i am running an 18x10 +18 on my HCR32 the tire size is a 225/40/18 in a Federal 595 i found federals run way bulkier than falkens i had before... fir more like a 235
fronts are a 17x9.5 and +17 offset with a federal again 215/45/17 and again they fit way larger than normal tires but in the end i have more grip with these tires then i did with larger shittier tires so i don't mind and i got the look i want... and i drift my car feel amazing just need more power
oh and hers the same wheels before powder coat and car when it was black you see how much i worked it to make it fit
Edited by JVDSKYRINE
wow, i like very much, imo i think they fit perfect, very snug!
can you go into details what you did to the guards??
good stuff,
federals tho i do not like very much,
i didnt understand one thing are you using 18x10 +18 or 17x9.5 +17
The 18x10 +18 are on the rears and 17x9.5 +17 are on the fronts by the looks of things.
that is correct... i honestly just took out my suspension in the rear.......blasted the fenders with a heat gun.....jacked the car up and threw some stacks of newspaper ontop of the wheel and tire..... lowered the car from the jack poppped the trunk ..... hopped in the trunk and jumped up and down until they fit hahhaa.... seriously its ghetto but this way you get a smoooth pull that flows with the body line not like those dumb lips you get with a fender roller
hi dude,
how the front tyres, touching anything when u turn? full lock?
hi dude,
nope as i said use the car for drifting so sure don't touch.... the problem with skylines is more rubbing on the front upper control arm rather than rubbing on the wheel well.... so i found with lower offset rims and smaller tires you can go a little lower.... I am putting adjustable upper control arms so i can fit them a little better and get my 3degrees up front.... when all the snow dissapears maybe i can get some action shots :D
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
