Hi all , many here have been wondering what sort of power characteristics Garretts GT3071R (CHRA 700177-5023) turbo gives on mechanically std RB25DET's . By standard I mean the factory exhaust manifold so that the GT30 IW turbine housings can bolt up . In another thread someone mentioned they're making 270 odd Kw at around a bar of boost with Garretts GT30 IW 0.82 A/R turbine housing . I'd very much like to know where they climb into boost engine speed wise and how it all feels with part throtle driving .
Thanks in advance , cheers Adrian .
  • Replies 71
I made 230rwkw at 15psi with mine. Has internal wastegate and is on the standard exhaust manifold. The only thing I did to the manifold was port it out a bit and remove some casting marks and stuff. Other usual mods - Power FC, front mount cooler. Still on stock AFM and injectors.
I see full boost at 3300rpm and part throttle driving is good too. Pulls really good too even in 5th.
Pretty sure I have the .63 exhaust housing. Got if from GCG cos thats what they recommended.
Edited by SmittyR33
Thanks , I'd really like to hear from people using Garretts GT30 IW turbine housings so we can all get an idea what to expect from using the 0.63 and 0.82 A/R housings .
Recently I thought I'd found a HKS GT3037 Pro S type turbine housing in 0.68 A/R but it turned out to be the 0.87 version , possibly a bit large for 2.5L and the 71mm GT compressor .
Cheers A .
That power doesn't really fall inline with the 'real' GT3071r. My bets are they supplied the cropped version.
OR.. Your dyno is simply very very conservative.
Sorry Disco to spam your thread but just to make it clear those figures the above has seen is not the norm from the real gt3071r.
Yes thats what I thought as well . You could get somewhere near that figure at the bleeding edge on a 2530 I'd think .
A while back ATP was claiming that the real GT3071R pulled up 500-1000 revs sooner than a GT3076R though the feeling overseas is that it doesn't work like that . Most people using the 3071R in the US have them on 2L fours so the results are not the same as you'd get on a 2.5L RB 6 - particularly in a 1370 odd Kg R33 .
Most people for cost reasons don't want to change their exhaust manifolds and until a twin scroll twin integral gate turbine housing becomes available (no time soon) the IW GT30 housings is all we have ATM .
In the other thread someone mentioned 270 Kw at 1 bar and I was hoping they would tell me what A/R turbine housing (assuming its a GT30IW one) and confirm the -23 cartridge number . I would think if it is the real one and the propper housing type it must be a 0.63 A/R turbine housing .
Given Mafias results (300 Kw from a real GT3076R 0.63 A/R) obviously the hot side can pass the gas but the burning question is can the GT30 turb/0.63 housing combination spin the 71mm GT compressor fast enough to make it feel good on a fairly std RB25 powered R33 .
If we can make this work it will bridge the gap between GT28BB turbos and the GT3076R IW . If not then the only answers I know of are not going to be affordable for many people .
Cheers A .
Edited by discopotato03
hey guys
I have seen the turbo with my own eyes - Its a ground out RB25 rear housing fitted to the 3071.
If you remember a while back, I had a T04S 3076 with a ground out RB25 housing and water meth, and with 18psi I managed to squeeze out about 245rwkw.
It needs a real garrett housing strapped on.
Edited by The Mafia
Final cost delivered was $1800. Thats with the 14lb actuator and bracket and exhaust flange. After I paid I found a company equally as big that was $150 cheaper. Anyhow, there's a holdup on delivery to make sure it is the right 3071. Will speak to them tomorrow.
Unfortunately I have to wait till I can get the time to do it as I work seven days a week. On the up side I have another car to drive around in January so may be ok then. Sorry guys. Parts are coming together slowly. Atp in the states are a big help, but don't talk to the receptionist, NOT helpful at all.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
