hey guys, woke up this morning, turned the ignition on, fuel pump was buzzed up like normal, i then turned to start it and it just clicked and did nothing. The starter motor had a slight reaction but not long enough. I kept trying but it had no reaction, just clicks over and thats it. Then for some reason the alarm would go off if i tried anymore than 3 times. What the hells going on? Could the starter motor be dead? Any light on this would be great.
Cheers,
Steve.
https://www.sau.com.au/forums/topic/193521-my-r32-wont-start/
battery is on its way out. most alarms i know have a feature that if the battery is disconnected then reconnected the alarm will go off. when your cranking the car over with a stuffed battery your sucking all the juice from the battery to the stater, so the alarm module looses power for a sec causing it to go off.
not sure what the dash lights doing, ill have to have a look when i get back from work, but the power turns off when i try, like the stereo, gauges, computers etc. So u think the best case is try another battery?
computers?
AFAIK the stereos will always turn off for second, but if the dash lights go off, then you havent got enough power .. battery or jump start time
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
