SAUWA CRUISE
Saturday Night Cruise
MEET POINT HAS BEEN CHANGED TO:
Where: Karrinyup Shopping Centre. Karrinyup Road
When: Saturday 8th December 2007
Time: 9.30pm for a 10pm Leave
Maps available on the night
PLEASE NOTE: CRUISE GUIDELINES APPLY! http://www.skylinesaustralia.com/forums/in...showtopic=37588 , Rules will obviously need to be followed. Any breaking of the rules, you will be asked to leave.
ALSO: NO REVVING YOUR CAR AT MEET POINTS OR TURNING YOUR SYSTEM UP LOUD! Stupid behaviour at meets points wont be tolerated.
We would like to get as many cars and people as we can. A huge turnout would be great!!! All Skylines and SAUWA members are invited.
Hope to see you all there!
Cheers
Brad
SAUWA Motorsport Co-Ordinator.
Edited by R DIRTY 3
https://www.sau.com.au/forums/topic/193534-sauwa-cruise-saturday-8th-december/
  • Replies 229
Posted Images
I think the cruise is for SAUWA members and SAU forum members, so if your on here and own a Cefiro/Stagea/Jap Import then your welcome, but we don't want other clubs to be invited, as big cruise attract alot of attention :wave:
I think the cruise is for SAUWA members and SAU forum members, so if your on here and own a Cefiro/Stagea/Jap Import then your welcome, but we don't want other clubs to be invited, as big cruise attract alot of attention :)
lol good luck with that :wave:
Im down like James Brown...
Cruise will be fine as long as no one reposts the cruise on other sites, otherwise prepare for hectik falcadores rocking neons and fully sik burnouts :wave:
I will not tolerate the knocking of Neons!!! :)
As Paul said, it is for SAUWA Members and forum members. So Skylines, Stageas, Cefiros etc are more than welcome to attend. Would prefer it is not posted on other forums.
Cheers
Brad
damn, will be in phuket :P
and im really looking forward to my first all skyline cruise as well.
hopefully next one.
No shit?
i fly out to phuket that morning at 630am, y is it every sauwa cruise that comes up i always have to miss ffs ;)
hmmm....??? i dunno maybe a cruise on aussie day or something, but then i spose ppl will be too busy getting hammered and going to the foreshore lol :nyaanyaa:
hopefully i will be able to get to one soon been hanging for it for a while now
Edited by Nick033
Just got told by work that I'll be spending the first three weeks of december in Newman. Guess I won't be coming :worship: Hopefully I'm in perth for the next one. Hope you guys have a good time :nyaanyaa:
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
