well my car has been off the road since about 2 weeks after the SAUWA drag day last yr (i think???) and it mayyyyyy just be ready 4 this cruise... turbos getting replaced this week and hopefully will be ready 4 the weekend *crosses fingers* but if i do come itll probably be one of the last 4 me as ill be selling my shitter with glitter and heading off to Melb soon... :P
none of you probably even know or remember me lol oh wellz :P
  • Replies 229
Posted Images
Hey Guys!
So far SKYRYAN and a few of my mates are joining us at Gateways at 830 for the cruise up to Karrinyup. Anyone else joining us???? Curious cos I don't wana leave anyone behind, oh wait, my car is faster then SKYRYAN's so I'm sure he'll be in my rear view mirror! :nyaanyaa:
haha
but yeah, let us know so we'll wait for ya!
Cheers
-jess
p.s. SKYRYAN is going to be wearing a skirt, so seriously worth joining us at gateways hey, we'll get our own private show!
Edited by jessr33
Ive already seen the private show....its over rated :nyaanyaa:
Hey Guys!
haha
Cheers
-jess
sounds good...just got me a 32 gtr so would be good to get to me the SOR people ;)
Hey Guys!
haha
Cheers
-jess
ill see if i can get down there, see if i can keep up with ryans new found power. ;)
Hey Guys!
So far SKYRYAN and a few of my mates are joining us at Gateways at 830 for the cruise up to Karrinyup. Anyone else joining us???? Curious cos I don't wana leave anyone behind, oh wait, my car is faster then SKYRYAN's so I'm sure he'll be in my rear view mirror! :rofl:
haha
Cheers
-jess
Yeh I know myself and another member will be there also. what time will we be takin off from gateways?
Umm good question.. is there going to be traffic on the freeway for the christmas padgent is it? If we are meeting Karrinyup @ 9.30pm then I think we should leave gateways around 8.50 - 9pm.
Thats a good point! I dont think the freeway should be a problem.
The cruise is probably going to be mainly highway/freeway running and wont be going near the city until late...so we wont be affected :rofl:
Hey Guys!
So far SKYRYAN and a few of my mates are joining us at Gateways at 830 for the cruise up to Karrinyup. Anyone else joining us???? Curious cos I don't wana leave anyone behind, oh wait, my car is faster then SKYRYAN's so I'm sure he'll be in my rear view mirror! :D
haha
Cheers
-jess
I`ll be joining you guy`s at gateway`s as well. I`ll be in the Pearl White R33 4-door.
Wow, seems like gateways is getting pretty popular, would meet you guys there but im am NOR so be a bit out of the way!! Like the food court dome roof? I helped install it, ooo and it wasn't me that Fu*ked up the join if any1 knows what im talking about :D
See you guys there!!!
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
