Egggggggg~~~~~~~~~~~
William_L
 Share
some a** h*** throw a box of eggs onto my car this morning.............
this is not the first time........... last time my sister 316i was the target, and now ...........my 33........
Are those f***ing a** h*** got too much time to waste? what the f*** they are thinking? :rofl:
I am thinking about who they are.
maybe because the noise of my car.
but there was a burnout sround on my Ave last night, just thinking are they relat or not.
I was so unhappy, coz this morning i am runnning out of time to go to my exam. And i have to wash my car before i went to exam.............. :rofl:
I had my 34 egged last week while the car was parked out the front of Calvary hospital while my wife was giving birth - left a nasty mark over the drivers door handle, and got egg yolk all down in my window winder mechanism - wish I could have caught the f$#%ers do it.
Are you sure it wasn't a delayed 'trick' from Halloween? Did you give lollies to all those that came knocking?
why do people in Australia celebrate halloween?
half the people who celebrate it wouldnt even be Catholic.
just another reason to go out and get pissed.
Agree, and when they come knocking, and you don't give a shite and have nothing for them!! Enoying!!
i never have been.
i wouldnt egg anyone else either. waste of eggs.
mmm eggs.
Likewise!!
Edited by Deluxe
um why do you associate Halloween with being Catholic?? :nyaanyaa:
Are those f***ing a** h*** got too much time to waste? what the f*** they are thinking? :nyaanyaa:
hmm are you down south??
becausing the original meaning of halloween comes from catholic history.
yeh, halloween isnt actually about getting lollies and looking like a dick while doing it.
 Share
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
    • Found some from 2009. The lobster bends were smoothed out on the inside with minimal gaps (perhaps 2mm) where the silicone joiners were used.
    • And if you have to drive it in a civilised (or excessively woke) US state, find a way to register and insure it in a redneck state, so you can roll coal in it without worrying about legalities.
