ive got a broken stud in my head for the exhaust manifold... its the very rearmost stud and ive already had a go at removing it, i drilled out the inside of the stud and tried to use an Ez-out to get it out but it snapped off in the hole that i drilled... im not having much fun here :P
what are my options?
https://www.sau.com.au/forums/topic/193653-broken-manifold-stud-removal-tips/
is there much of the easy out sticking out the hole? could try welding a nut to it and using a spanner. or go a get a right angle drill, about 10 drill bits (or if your any good at sharpening them do that instead), and some patience, and drill the EZ-out out. use right twist drills for this and hopefully the if the drill grabs it will loosen the EZ-out and screw it out.
to remove broken studs i always use left twist drill bits, when your drilling the stud the drill bit also unscrews the stud at the same time, easy.
a couple more ways would be:
we sometimes remove broken taps (same steel as an EZ-out) at work with an oxy/acetylene kit, with a really small tip heat the tap till its really hot, then turn the acetylene off, the oxygen blasts the tap out.
a costly method would be with a spark eroder.
or remove head and get it milled out.
Leave it for the experts, you're only making matters worse.
I had exactly the same problem, same position.
I found it while the engine was out so I tossed it in the trailer and off to the local muffler fitter.
He MIG welded a washer to the remains of the easy-out and then welded a nut to that washer. After a couple of attempts, he unscrewed the broken easy out. (Our problem was we didn't know if it was an easy out or a drive in type of stud tool)
Then he MIG welded another washer down onto the remains of the broken stud, and then welded a nut to that washer too.
It unscrewed easy peasy from all the welding heat.
He's a great welder with steady hands and eyes that still work. Whole job cost me $25.
I'd rather remove an engine/gearbox than pull the head with all the associated gasket costs etc of re-fitting the head.
thats all well and good but in my case the stud has snapped off inside the head, so that eliminates welding something onto it to remove it...
No mine was exactly like that, recessed inside the head.
Just takes a steady hand and good eyes with a MIG.
cant help you with the stud, but i have a good stress relief teqnique for you. Try throwing a spanner as hard as you can against a brick wall, then drink too much jacks and coke. Thats what i did and the problem disappeared right up until the next morning.
it just takes time and patience, and you'll get it. Since it the most rear stud it might be worth your while in getting a right hand drill adaptor like it was said above. Just drill the inside of the stud, slow and steady and peel the stud out and run a tap through to tidy up the thread.
Its a pain in the ass but nothing an hour with the drill and a few drill bit wont fix, good luck :nyaanyaa:
Edited by R34GTFOUR
what i have done in the past is used a drill bit about the same size as the stud and tryed to get the drill to grab and spin the broken stud done to the bottom of the thread, once it is down the bottom you can tap out the outside of the thread and then with a bit of lube the stud will come straight out with an ez out.
happy hunting. :nyaanyaa:
Listen to Zertek, the mans a god! :nyaanyaa: rofl s**t'a'copters
deary - if u cant jimmy it out... leave it to the professionals who qoute time and money... did i just say that? Faaark meh
happy hunting. :worship:
if you use a left twist drill instead of spining the stud down to the bottom of the thred it spins it out :nyaanyaa:
if your in adelaide ring up captain thread he is a mobile guy does it in about 20 mins i had 3 broken studs he had them all out and cleaned up the threads in about a hr cost about 90 bucks from memorey
I have had 2 snapped and recessed studs removed using this method. I'm pretty sure this is how most exhaust places would do it too.
yeah, but the rear stud is in an absolute prick of a position and you would have to be a magician to get a weld in there, let alone a decent one
no1 use crc when removing exhaust studs anymore?
n make sure when u put ur new studs/bolt in u put some never seize on them so they well never seize again lol
jus ring the tread doctor or another such mob pay the cash n be done with the headache (n im not 1 to throw money around but sometimes with the headache VS the cost, the cost wins...)
i had 7 broken studs on an RB30. Drilled the whole way through the broken stud, sprayed some WD in behind the stud through the hole i just drilled then proceeded to drill the next and spray etc etc. after all were drilled and sprayed i got a TORX bit with plenty of teeth on it (like a double hex allen key but it adapts to a socket so you can ratchet it out) that is just a bit too big for the hole, the tighter the better, tapped it in with a hammer and then first wound it in half a turn then wound it out all the way. if the TORX bit slips in the stud drill a bigger hole use a bigger bit. I've found extractors to be very brittle and easy to snap, the TORX is both hard and strong so the chances of it braking off in the stud are slim to none. I understand space is at a premium, but if you can get an angle head drill in there your set. Hope this helps.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
